I’m slowly working towards hopefully getting a SatNOGS station setup in the future. A little strap for cash at the moment, so I decided to build a Turnstile antenna following this guide (which is in use in this station by @mwheeler and this station by @IZ7BOJ). Here’s my rendition:
I borrowed a N1201SA Antenna Analyzer to measure the performance of the antenna. At 437.2 MHz, which is the frequency I’m most interested in, the VSWR was ~2.3 (not great…). Impedance was ~48 Ohm, which I think isn’t too bad. Not sure how to interpret the other results (resistance and reactance), here they are:
What do you guys think of these values? For a homebrew antenna, is this what’s to be expected or could it be improved? And if so, any ideas on how to improve it? I’ve yet to buy an LNA, which would be the natural next step, but I’d like to squeeze more performance out of this if possible…
Any help will be kindly appreciated.
Best wishes,
Dan
P.S. Some additional pictures of the measurement setup with the N1201SA and of the interior of the antenna:
it has been suggested to me to be sure to ground the outside of the coax to a real ground when using a VNA. I’ve tried this myself and it makes a big difference.
Hi Dan,
I never measured VSWR of my antenna because my miniVNA works up to 200MHz.
Your impedance matching should be better, I suggest to do the tests proposed by @uy0ll, in order to understand wheter the problem is the matching network or the radiating elements.
Alfredo
I’d not heard about grounding the coax, and those measurements are ungrounded. I had to redo the impedance matching components several times to work out where the critical measurements were, that and a little clipping of the threaded bars to tune it. It’s now the best antenna I have for this frequency.
I am sorry for the very late reply, but I finally got back to the project. I haven’t been able to tune the antenna further, but I will attempt to do so following your guidelines. For now, I wanted to let you know that I sucessfully installed the antenna with and RPi and conducted some testing. It’s set up as Station 831! At least, I’ve been able to hear some birds (although too faint to decode). Here’s an example of GOMX-1.
