HADES-SA (SpinnyONE) (SO-127) Transmissions
using recording obs from @K4KDR and @pu4elt (thank you for both of you!) , i try ssdv decoding using ssdv2sat and soundmodem uz7ho. and it work flawless.
the ssdv2sat can decode ssdv from lapan-a2, silversat, hades-sa and standard or non standard ssdv. latest version also can decode more data telemetry from silversat.
There should be a mode for SSDV observations, not only fsk200 and fsk800 - something like USB 3khz bandwidth. I have some observations with strong signal but they were cropped by internal filters.
Suggest you use a tool like Audacity to visually inspect the recording that YOU create, and compare it to a recording of the downlink that DOES decode properly.
I would guess you’ll see a difference in level or some other characteristic.
For example, a recording make from mic and speaker will probably have cut off high & low sections of the audio freq. Not good for data!
Another nice Hades-SA pass w/ partial image #'s 215, 216, & 217. SO much easier to decode live w/ doppler tracking as opposed to tuning manually on a replay! (fine-tuning required w/ these early TLEs, of course)
Three complete images and a partial one from an 88 deg overhead pass.
Turnstile antenna + LNA/BPF in Greece.
12:48:26 hades_sa_image_214.jpg
12:49:04 hades_sa_image_215.jpg
12:50:22 hades_sa_image_216.jpg
12:50:55 hades_sa_image_217.jpg
If you get run-detectors: unable to find an interpreter for ./ssdv-merge-windows-x86.exe under Linux’s WINE, just use the cat command and the Linux version of ssdv.
Run from the directory with the .bin files of only one image ID:
cat *.bin > all.bin
and then:
./ssdv -d all.bin ssdv.jpg
2026-04-03 12:51 217
2026-04-03 12:51 + 14:2x 218
2026-04-03 14:2x 219
2026-04-03 14:2x 220
2026-04-03 14:2x 221
2026-04-03 14:2x 222
2026-04-03 14:2x 223
HADES-SA 00:12-00:21 UTC
Photos - 214 215 216 220 221 222 223
Hello ALL,
i have success with ssdv decoding from hades-sa , ok the software works fine to decode a image even partial.
i am have try to decode the codec2 audio file with the run_codec2.bat file , but i am stuck with errors , missing libraries and finaly giving a 0x000007b error .
can someone tell me why i have a error with c2dec .
this seems to be a system errror ?
in attachment some decoded audio frames .bin
can not covert the c2 file to .wav ffmpeg does not do the job.
after click ok with no libraries i get this screen.
can someone compile the c2dec.exe for windows 11 64 bit?
[sat_03_type_11_codec2_frame_014.zip|attachment]
(upload://w7J5xhzZs9ckx4u86acmzIulcvR.zip) (5.4 KB)
good luck with it
on7ndr
Thanks for the audio file bali .
but not getting audio from code2.bat , errors in the c2dec software
look inside run_codec2.bat, and there is command:
codec2-merge-windows-x86 codec2_file_list.txt hades_sa.c2
do you success create the hades_sa.c2 ?
Same problem here. Raw audio file could not be created on Windows 10.
I managed to create the .raw file by running the batch file on Windows 7. But still no conversion into .wav.
By moving the raw audio file to the windows 10 PC and running again the batch file, the wav file was finally there!
Codec 2 for Linux (Ubuntu-like systems):
Run sudo apt install codec2 once.
(Installs c2dec)
Then for every bunch (ID) of Codec 2 .bin files:
cat *.bin > all.c2
then
c2dec 700C all.c2 all.raw
and finally
ffmpeg -f s16le -ar 8000 -ac 1 -i all.raw all.wav
sorry but problem not solved for windows 11.
i can not get it working…
why no support windows 11???
Because Linux is much better.
i have not a hades_sa.c2
can c2dec not be recompiled for win 11 ?
it should can. but i never compile on windows. i compile in linux, and no need many dependency.
in linux only run this for compiling:
i think in windows should be easy too
you can get the source here:
or just run this (no need to install ffmpeg, and convert to wav)
aplay -f S16_LE all.raw
sorry i do not use linux , the software on amsat-ea should work on windows
