Hi all,
I’m writing for my first time a kaitai decoder -Hades-D telemetry-. I’m using the kaitai web ide, and my (maybe stupid) question is about the “object tree” section. With a sample data uploaded, I can only see the first byte elements (type and address) in this section, although I have described the rest of the elements for the frame. Does it mean that something is wrong?
Below my code:
meta:
bit-endian: be
endian: be
seq:
- id: cubesat_frame
type: cubesat_frame
types:
cubesat_frame:
seq:
- id: first_header
type: first_header
- id: metadata
type:
switch-on: first_header.type
cases:
0b0001: power_frame
0b0010: temp_frame
0b0011: status_frame
0b0100: powerstats_frame
0b0101: tempstats_frame
first_header:
seq:
- id: type
type: b4
- id: address
type: b4
power_frame:
seq:
- id: spa
type: u1
- id: spb
type: u1
- id: spc
type: u1
- id: spd
type: u1
- id: spe
type: u1
- id: spf
type: u1
- id: vbus1_raw
type: b12
- id: vbat1_raw
type: b12
- id: vcpu
type: b12
- id: vbus2_raw
type: b16
- id: vbus3_raw
type: b12
- id: vbat2
type: b12
- id: ibat
type: b12
- id: icpu
type: b12
- id: ipl
type: b12
- id: powerdul1
type: u1
- id: powerdul455
type: u1
- id: vdac
type: u1
- id: checksum
type: u2
In the object tree I can see a cubesatFrame item with a child firstHeader item, with type (1) and address (8) properties well decoded, but I’m missing all the power_frame items.
The sample data I’m using is the following: “18 3E 03 06 55 00 00 2B B6 6B 67 F9 A3 B3 3F 0F F6 01 F3 00 10 51 00 00”
Thanks all of you in advance.
Pedro Cabrera
