How can we build a Grafana dashboard using satellite data from SatNOGS. What data source are we supposed to specify and how shall we do it?
You first have to build a decoder (.ksy file) and add it to the system.
Within this decoder you specify the data fields to which Grafana should later have access.
Thanks for the reply, can you also guide if after submitting the decoder in KSY we will get any SUID that is required in every panel on graphana dashboard.
The SUID is the NoradID of the satellite.
About what satellite are we speaking?
