I want to fetch the value of Doppler Shift from GPredict for a satellite.So, please suggest some way by which we can export value of a parameter from the source code.
@cp1: Do you want to have the current Doppler shift of a selected satellite from within GPredict available to an external program in real-time? Which other parameters are you interested in?
In order to get the doppler-corrected frequency in real-time you can interface GPredict with any radio model in rigctl (from the hamlib package).
By adding a pseudo radio model to rigctl you would have an export of the doppler-corrected frequency (and thus almost the Doppler shift you are interested in).
The only other parameters this is possible for are AzEl/pointings from a certain location to the selected satellite. For those you could add a psedo anntenna-rotator model to rotctl (also a hamlib tool).
Sincerely,
kerel
Thanks for the solution. I will try implementing the above solution.
Basically, I need to feed the doppler corrected frequencies to a receiver IC (not a radio) present at my location.So, is there any other do this method to do this ?
