I am using the latest version of Gpredict in Windows 10 and have the follow set up in rotctld:
rotctld -m 601 - r com3 -t 4533 -vvv
But when I run antenna control in Gredict I get an Error and in the command propmt window I get the following error:
C:\Program Files\hamlib-w64-4.5.5\bin>rotctld -m 601 - r com3 -t 4533 -vvv
Opened rot model 601, ‘GS-232A’
read_string_generic(): Timed out 0.614 seconds after 0 chars, direct=1
read_string_generic(): Timed out 0.667 seconds after 0 chars, direct=1
read_string_generic(): Timed out 0.633 seconds after 0 chars, direct=1
read_string_generic(): Timed out 0.670 seconds after 0 chars, direct=1
read_string_generic(): Timed out 0.617 seconds after 0 chars, direct=1
I did have it working but now it will not work
Any ideas?
