Gpredict and rotator control
Hello,
I am trying to build my own ground station.
Before start building hardware staff, I would like to test gpredict and how communication works.
I setup an ubuntu pc, with gpredict and hamlib.
I create virtual ports using the following command:
socat -d -d pty,rawer,echo=0 pty,rawer,echo=0
which creates the ports /dev/pts/1 and /dev/pts/2
next I give the command:
sudo rotctld -m 202 -r /dev/pts/1 -s 9600 -T 192.168.79.12 -t 4533 -C timeout=5000 -C retry=0 -vvvvvvvv
and seems that something is waiting for and after that I go to gpredict, and track satellite using the antenna rotator. but I cannot see any message in the terminal.
I sure that I setup something wrong, but can anyone give me a hint?
Thanks in advance.
Do you want to emulate a rotator ?
In that case, start rotctld with model 1 (dummy), no ports required.
rotctld -m 1 -t 4533 -vvvvvvvv
and then in another terminal, try it with rotctl -m 2 -r localhost:4533 or with gpredict.
Thank you!!!
It works in the terminal, but not with GPredict. I can’t find the problem.
C:\Users\Michel\Desktop\ham\gpredict\hamlib\bin>
C:\Users\Michel\Desktop\ham\gpredict\hamlib\bin>rotctld -m 1 -t 4533 -vvvvvvvv
rotctld, Hamlib 4.5.5 Apr 05 11:43:08Z 2023 SHA=6eecd3
Report bugs to hamlib-developer@lists.sourceforge.net
rot_init called
initrots4_dummy: _init called
rot_register (1)
rot_register (2)
dummy_rot_init called
set_conf: called
rot_open called
dummy_rot_open called
dummy_rot_open: dummy rotator so simulating speed
Opened rot model 1, ‘Dummy’
Backend version: 20220531.0, Status: Stable
Connection opened from ::1:49158
rotctl(d): Å ‘’ ‘’ ‘’ ‘’
icrosoft Windows [Version 10.0.19045.5131]
(c) Microsoft Corporation. All rights reserved.
C:\Users\Michel>cd C:\Users\Michel\Desktop\ham\gpredict\hamlib\bin>
The syntax of the command is incorrect.
C:\Users\Michel\Desktop\ham\gpredict\hamlib\bin>rotctl -m 2 -r localhost:4533
Rotator command:
What exactly do you mean with “not with gpredict” ?
Does it connect then immediately disconnect ?
Only worry I see there is the IPV6 adress, I dont know what the compatibility is on that. in gpredict you might specify the IPV4 adress instead: 127.0.0.1
Hello
Here we go, I’m making progress! In the meantime, I’ve investigated a bit more.
I’m using the command rotctld -m 1 -t 4533 -vvvvvvvv with Gpredict, and it works fine.
However, I’d like to avoid using Hamlib if possible, as I can already get the virtual rotor’s position up to its destination.
I’d like to directly retrieve the AZ and EL positions from Gpredict and integrate them into my code in the IDE for the ESP8266, which will control my motor (link: Dispositif de EAU de moteur d'inclinaison panoramique extérieur, télécommande, rotation horizontale et verticale, caméras de vidéosurveillance, budgétaire, entrée AC 220V - AliExpress 30).
For now, I’m forced to use rotctld.
73’s
my ide code
#include <ESP8266WiFi.h> // Inclure la bibliothèque Wi-Fi pour ESP8266 (nécessaire pour la connexion au réseau)
// Informations de connexion Wi-Fi
const char* ssid = “-------------”; // Nom de votre réseau Wi-Fi (remplacez par le SSID de votre réseau)
const char* password = “------------”; // Mot de passe de votre réseau Wi-Fi (remplacez par le mot de passe)
// Informations sur le serveur rotctld
const char* host = “192.168.1.176”; // L’adresse IP du serveur rotctld (ici, l’IP de votre PC qui exécute rotctld)
const int port = 4533; // Le port sur lequel rotctld écoute, par défaut 4533
WiFiClient client; // Créer une instance de client Wi-Fi (utilisé pour établir une connexion réseau)
void setup() {
// Initialiser la communication série pour afficher les informations sur le moniteur série
Serial.begin(115200); // Démarre la communication série à 115200 bauds (pour affichage sur le moniteur série)
delay(10); // Attendre 10 ms (petite pause pour s’assurer que tout est initialisé)
// Connexion au réseau Wi-Fi
Serial.print("Connexion à ");
Serial.println(ssid); // Affiche le nom du réseau Wi-Fi auquel nous essayons de nous connecter
WiFi.begin(ssid, password); // Démarre la connexion Wi-Fi avec le SSID et le mot de passe spécifiés
// Attendre que la connexion Wi-Fi soit établie
while (WiFi.status() != WL_CONNECTED) { // Boucle tant que la connexion n’est pas réussie
delay(500); // Attendre 500 ms entre chaque tentative
Serial.print(“.”); // Affiche un point pour indiquer que le programme tente toujours de se connecter
// Une fois connecté au Wi-Fi, afficher l’adresse IP obtenue
Serial.println(“”); // Ligne vide pour améliorer la lisibilité
Serial.println(“Wi-Fi connecté”); // Affiche un message de confirmation
Serial.print("Adresse IP : ");
Serial.println(WiFi.localIP()); // Affiche l’adresse IP locale de l’ESP8266 (utilisée dans le réseau Wi-Fi)
// Connexion au serveur rotctld (via l’IP et le port)
Serial.println(host); // Affiche l’adresse IP du serveur rotctld auquel l’ESP8266 essaie de se connecter
if (!client.connect(host, port)) { // Essaye de se connecter au serveur rotctld à l’adresse IP et au port spécifiés
Serial.println(“Échec de la connexion”); // Si la connexion échoue, affiche un message d’erreur
while (true); // Bloque le programme si la connexion échoue (infinite loop)
// Si la connexion au serveur est réussie, afficher un message
Serial.println(“Connecté à rotctld”); // Affiche un message pour indiquer que la connexion est réussie
void loop() {
// Envoyer la commande pour obtenir la position AZ/EL depuis rotctld
client.print(“p”); // Envoie la commande “p” suivie d’un saut de ligne, qui demande la position du rotor
// Lire la réponse du serveur rotctld
if (client.available()) { // Si le serveur a envoyé une réponse
String response = client.readStringUntil(‘\n’); // Lire la réponse envoyée par le serveur jusqu’à la nouvelle ligne (\n)
Serial.print("Position reçue AZ : "); // Affiche le message “Position reçue :”
Serial.println(response); // Affiche la réponse reçue (AZ/EL) dans le moniteur série
// Attendre 1 seconde avant de refaire une nouvelle requête pour obtenir la position
delay(5000); // Attendre 1000 ms (1 seconde) avant de refaire une nouvelle requête au serveur
It sounds like you want to implement hamlib on the esp8266 then, so it can take the role of rigctld straight up.
In that case, I suggest implementing one of the simpler protocols like easycomm or gs232a/b. maybe this even exists already.
I had looked into it, but EasyComm allows controlling the motor by receiving manual commands or through software like Gpredict. However, in the library, there is no option to receive the AZ and EL coordinates of the targeted satellite. There must be a way to retrieve the data displayed on the software during its pass, right? I’d rather write my own code based on the requirements and the magnetic sensor I plan to add. Thank you so much for all the information. I’m looking into it… If you have any ideas, I’m all ears!
I’m not sure what you’re aiming for here. Hamlib is for control, Gpredict/Orbitron etc is for pointing, to Hamlib for example. Gpredict spews out the pointing of the targeted sat live, not sure what more you’re asking for.
If you want something that does TLE straight to pointing on a micro, then it’s another ballgame.
I made a thing some time ago that does this for doppler, should be pretty easy to modify for az/el commands I believe.
Hi Michel;
I’m not sure if you are still looking for the answer to this question, but I am sure it is possible to do what you want -
I like your idea to write your own code - for I don’t like Gpredict very much, and I have come to dislike hamlib even more over the last year or so. But is it really the only solution for many people - unless you can write your own code.
When I started to try and get those programs to work with my Yaesu FT-818ND, it was just problem after problem - and after doing much “code browsing”, I have a much better idea how those programs work - or fail. I also learned to write my own code.
If you are building a “rotor”, then of course you need to send the AZ and El commands to it. If you don’t want to use hamlib, then of course you may not use gpredict (or any other program that uses hamlib) - and so then you must either find a source for the data, or you can calculate the AZ and EL (yes, it is possible) and then generate the commands yourself. It all is up to you.
I have written programs that use both methods of generating AZ and EL commands and sending them to my rotor.
Another way if you want to use gpredict as the source your data, then you could “capture” the output with a program that emulates a rotator as SA2KNG suggests…
I think it is not too hard to modify your ide code to and create a TCP connection that will get you the data. What you do with that data is up to you then, of course.
Hope this helps - and 73.
I solve it so believe the Gpredict.H, I share it. Also remember the pins you have to modify.
  • @file gpredict.h
  • Permet la connexion directe Wifi depuis GPredict, sans passer par hamlib/rotctld.
  • Pour carte Wemos D1 Mini Pro
#ifndef LIBRARIES_GPREDICT_H_
#define LIBRARIES_GPREDICT_H_
#include <ArduinoWiFiServer.h>
#include <Arduino.h>
#include <WString.h>
#include <WiFiManager.h> // Biblioteca para gestión de WiFi
#include “rotator_pins.h”
#include “globals.h”
#define PORT 4533 // Puerto para el servidor
ArduinoWiFiServer server(PORT);
class gpredict {
public:
    @brief    Initialization
void gpredict_init() {
    WiFiManager wifiManager;
    // Iniciar WiFiManager y configurar conexión
    wifiManager.setTimeout(180); // Tiempo de espera de 3 minutos
    if (!wifiManager.autoConnect("LW2DYB-R")) {
        // Si no se conecta, reiniciar
        Serial.println("Fallo al conectar. Reiniciando...");
        delay(3000);
        ESP.restart();
    // Conexión exitosa
    IPAddress ip = WiFi.localIP();
    digitalWrite(WIFI_LED, HIGH); // Wifi LED on
    Serial.println();
    Serial.print("Conectado a WiFi. Escuchando en ");
    Serial.print(WiFi.localIP());
    Serial.print(":");
    Serial.println(PORT);
    server.begin();
    @brief    Get the commands from telnet and response to the client
void gpredict_proc() {
    char buffer[BUFFER_SIZE];
    char incomingByte;
    char *Data = buffer;
    char *rawData;
    static uint16_t BufferCnt = 0;
    char data[100];
    String str1, str2, str3;
    // Returns first client which has data to read or a 'false' client
    WiFiClient client = server.available();
    // client is true only if it is connected and has data to read
    if (client) {
        ESP.wdtFeed();
        incomingByte = client.read();
        str3 = String("\n");
        // Read new data until '\n'
        if (incomingByte == '\n' || incomingByte == '\r') {
            buffer[BufferCnt] = 0;
            if (buffer[0] == 'p') {
                // Send current absolute position in deg
                str1 = String(control_az.input, 1);
                str2 = String(control_el.input, 1);
                client.print(str1 + "\n" + str2 + "\n");
            else if (buffer[0] == 'P' && buffer[1] == ' ') {
                client.print("RPRT 0\n");
                // Get the absolute position in deg for azimuth
                rotator.control_mode = position;
                rawData = strtok_r(Data, " ", &Data);
                strncpy(data, rawData + 2, 10);
                char* az = strtok(data, " ");
                char* el = strtok(NULL, "\0");
                if (isNumber(az) && isNumber(el)) {
                    control_az.setpoint = atof(az);
                    control_el.setpoint = atof(el);
            else if (buffer[0] == 'S') {
                // Stop Moving
                control_az.setpoint = control_az.input;
                control_el.setpoint = control_el.input;
            // Reset the buffer an clean the buffer
            BufferCnt = 0;
            //server.flush(); // flush the buffers
        } else {
            // Fill the buffer with incoming data
            buffer[BufferCnt] = incomingByte;
            BufferCnt++;
private:
bool isNumber(char *input) {
for (uint16_t i = 0; input[i] != ‘\0’; i++) {
if (isalpha(input[i]))
return false;
return true;
#endif /* LIBRARIES_GPREDICT_H_ */
/// Sorry item in spanish my callsigin and “connected wifi listen on”
Michel;
Here’s a a crude Python loop to get az/el from gpredict:
import socket
import time
gp_ip = 'localhost'
gp_port = 4533                  #Standard rotator TCP port
rotor_pos=b'123.45\n67.89\n'    #Current (simulated) rotor position
print('\nWaiting for gpredict command to engage your rotor...')
gp = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
gp.bind((gp_ip, gp_port))
gp.listen(1)
conn, addr = gp.accept()
gp_connected=True
print('\nConnection address:', addr)
while gp_connected:
    if not conn._closed:
        packet = conn.recv(30)
    print('\ngpredict command received:', packet)
    if packet==b'q\n':      #gpredict is closing the connection
        conn.close()
        print('Connection terminated by Gpredict...')
        gp.close()
        gp_connected=False
    elif packet==b'p\n':    #gpredict requesting rotor position
        conn.send(rotor_pos)#fake rotor position back to gpredict
        print('response to "get_pos" command sent:', rotor_pos)
    elif packet[0:2]==b'P ':#gpredict setting rotor position
        mstr=b'RPRT 0\n'    #fake "no error' back to gpredict
        conn.send(mstr)
        print('response to "set_pos" command sent:', mstr)
    else:
        print('Other command', packet)
        mstr=b'\n'          # fake ack back to gpredict
        conn.send(mstr)
        print('response sent:', mstr)
    time.sleep(1)
exit()
Start the program, then open up gpredict, open the antenna control, select a sat, and hit the “ENGAGE” button. You could add your functionality to the “set_pos” section to parse the az/el values from the “P” command string, and then send the data via a TCP port to your hardware. I think you have to use a different port (not 4533) to communicate with the rotor if you are using TCP (that port is in use for communication to gpredict). I used 4535. This is how to get away from using hamlib !!
Hope this helps…
73 and good luck!
