Gpredic and Icom ID-5100a
Hi, could you see if I have the Hamlib command correct for using Gpredict and the Icom ID-5100a.
I show the command line I use to start Hamlib below, and the errors I recieve once it starts. I show my current interface configuration below that. Any assistance would be greatly appreciated.
Thanks Jim Garrity
Hamlib Command Line:
jimgar@jimgar-HP-EliteBook-8560p:~$ rigctld -m 371 -r /dev/ttyUSB0 -c 8Ch -s 9600 -vvv
Opened rig model 371, ‘ID-5100’
Closed rig model 371, ‘ID-5100 - will reopen for clients’
Closed rig model 371, ‘ID-5100 - no clients, will reopen for new clients’
Log Browser:
2023/11/19 20:01:38 ERROR gtk-rig-ctrl.c:check_set_response: setup_split rigctld returned error (RPRT -13 2023/11/19 20:01:38 ERROR )
2023/11/19 20:01:38 ERROR gtk-rig-ctrl.c:check_set_response: set_freq_simplex rigctld returned error (RPRT -13 2023/11/19 20:01:38 ERROR )
2023/11/19 20:01:40 ERROR gtk-rig-ctrl.c:check_set_response: set_freq_toggle rigctld returned error (RPRT -13 2023/11/19 20:01:40 ERROR )
Radio Interface Configuration:
Name W7JRG
Host localhost
PORT 4532
Radio Type Full-duplex
PTT status None
VFO Up/Down MAIN ^/ SUB v
Lo Down 0
Lo Up 0
