Gnuradio progress!
Had a lot of gnuradio success today! Still a lot of work to go, and aside from the voice demod from SO-50 I have not had a chance to try decoding any data packets from the others, and I would not expect them to decode, but we are getting closer! The amount of voice decoded from SO-50 alone is an epic win, about 9 minutes worth!
Note, on the cw birds this is going through an FM Demod process - ultimately when selecting a CW mode for a satellite in network we will want a different demod process on the client, but hearing something is promising at the least!
SO-50 (voice): https://network-dev.satnogs.org/observations/760/
SEEDS II (CW): https://network-dev.satnogs.org/observations/762/
STRAND-1 (data): https://network-dev.satnogs.org/observations/763/
CO-65 (CW): https://network-dev.satnogs.org/observations/764/
ALSAT 1N (data): https://network-dev.satnogs.org/observations/765/
The gnuradio script is below. This is my own amateur edit, improvements are very much welcome: https://github.com/cshields/gr-sandbox/blob/fd40ca9d5047499ff280c20fcd2cbfa5c6d9d69a/fm_demod_cshields.grc
/cc @Acinonyx @pierros @surligas @fredy
Hi kb9jhu,
If you are able to extract Alsat-1N frames would you mind to send me a file with them?
I would like to do some experiments and I have a particular interest on that satellite.
Many thanks,
Alberto
Are you looking for the frames or the audio to generate them?
If the latter, click on the green ID numbers here: https://network-dev.satnogs.org/observations/?norad=41789
If they are green I have checked and verified them good. Red means I’ve verified them “empty”… Yellow is either undetermined or not triaged.
You can then download each data file (look for a button below the audio spectrum) and decode.
I am looking for the frames. I am developing a tool for processing any kind of frame.
Regards,
Alberto
