hi i’m a college student in korea, I want to receive the CUAVA-2 signal, but when I convert PDU to stream and then to AX.25, the address doesn’t display correctly. I’m using a BladeRF SDR with Osmoscom. If you’re familiar with GNU Radio, could I get a sample flowchart, or could you help identify any issues in my GNU Radio flowchart
Also, what do you mean by “the address doesn’t display correctly”?
– I mean The hex data address field doesn’t match, meaning the address field—such as AC 96 64 AA A6 B2 for CUAVA-2—doesn’t align with my expected data. I think the HDLC deframer may have passed on incorrect data.
Thank you so much for helping me out. I’d appreciate it if you could check the parameters in my GRC file, and I don’t have a WAV format file available.
is correct, it’s shifted 1 bit to the left according to the AX.25 protocol.
If you shift it back 1 bit to the right, you will get an ASCII code where you can directly convert to VK2USY, CUAVA-2’s callsign.
I’m sorry for the misunderstanding, what I meant is that my data doesn’t come out like that.
Is there a criterion for determining the parameters of a low pass filter, symbol sync, and Costas loop? It’s because the signal doesn’t seem to be properly filtered.
I tried to reconfigure your flowgraph to process .wav files, but had no success yesterday evening. Will have a look on it at a later time. Currently new satellites are in orbit catching my attention.
I also had no luck using your flowgraph.
However, switching to bpsk.grc from gr-satellites with minor modifications, I got my wav recordings correctly decoded.
Thank you so much for your help.
By the way, how can I apply your .wav recording file to your .grc file?
It’s my first time using Audio Source block. So please forgive me.
We’ve tried using Wav File Source → Audio Sink so that we can apply .wav file to Audio sink, which was not working.(1st pic)
AND also tried Wav File Source itself.(2nd pic)
+) We are using bladeRF, so now we are working on using “osmocom source”, which can receive IQ file(complex type). If you know how to connect your flow chart with blade RF, please tell us.
Thanks so much for your help!!
Just use an audio player to play the wav file. The block Audio Source takes the sound card’s output as input. Make sure your audio out goes into gnuradio or both meets on “monitor” by checking the audio mixer of your system.
As for bladeRF I’m not a good help since I don’t have such a hardware.
Thank you! i’ll ask you one more question, why did you multiply the signal source?? and why did you use a multiply const block in the middle?? are there any criterion??
I’ve fully understood the demodulation flow chart you provided, but I think there might be an issue with how I’m receiving my signal. Could I refer to the flow chart you use when receiving a WAV file?
also, do note that the bpsk flowgraph in satnogs records with a 12k offset, which is normally handled by gr_satellites automatically. but any flowgraph that wants the bpsk signal at 0Hz need to move that down.
the -1.5k cosine in the flowgrah image above, is usually what does this, but 1.5k is only useable for 1200baud bpsk (why it was changed to 12k).
explained in detail at gr_satellites command line tool — gr-satellites 5.7.0-git documentation
