Hello Sir:
No transmission in the orbit 1927. It was scheduled 13.12 at 10:04z. I copied the sat beaconing with good signal but did not send image.
Can you confirm if it will be sending image at 11.34z as you have informed before?
73
David EA4SG
Hello Sir:
73
David EA4SG
Hello!
I scheduled a transmission but it was erased after service seance. I will schedule new transmissions above Spain in a few days.
gr_satellites 53385 --rawint16 ~/iq_57600_6514407.wav --samp_rate 57600 --iq --use_agc --kiss_out out.txt
Thank you so much!!
Another interesting idea - perhaps take a series of images and try to transmit them in order. Perhaps an image of the moon setting behind the atmosphere? I think TUBIN made a beautiful series of images detailing that.
It worked well! Thank you very much!
Hello!
We would like test our X-band transmitter. Yet there was no signal received. We know that our transmitter works. Only thing left is to try to catch signal. If someone is interested in testing. Please let me now here or in PM: date and time when you will be able to try, qth locator and parameters of your antenna. Then I will schedule carrier transmissions.
Brief info about X-band transmissions:
GFSK 125kb ~500 kHz bandwidth 10492 or 10498 MHz 10 sec carrier
New image transmissions for 15.12 scheduled (UTC Time):
Image 1: 09:13:30 + 09:15:00 + 09:16:10
Image 2: 10:42:45 + 10:44:00
Image 3: 15:27:00 + 15:28:10
I may be able to. When I get home I’ll check the passes to see what’s up
Hi, does anyone have some audio files of decoded image transmissions to test a new beta version of my software?
Are these scheduled transmissions (15-12-2022) in the X-Band or in the UHF band?
In the UHF. I need to know who want to try to receive X-band before scheduling:)
Have some one been able to receive and decode some images? It would be nice to see all three!
The first two are out of focus ?
Hmm. Interesting… Should not be. Camera have fixed focus. Probably it faceing space on both pictures
Sprayed in the eye by ISS ?
this is the third, best I could do:
From my observation 6878661 with 999 frames – static 5-element yagi pointed north, about the same result
Great! You can see some land of east coast there:)
Ok, I have discovered another bug with my program. will try to fix it later.
very cool and thanks for all your efforts on this!
