Hehe gonna receive this one =D
Thanks for the info, keep us posted! Satellite use of the 3cm band is really rare, so your efforts are very interesting to follow
Received and processed from my observation 6843220 @ 15:45 UTC
Beautiful! Thank you!
You can see New Zealand far away isn’t it?
Transmissions:
09/12/2022 08:42:55
09/12/2022 10:13:00
10/12/2022 09:47:30
@SA2KNG Hello!
Have you been able to decode image from this observation? (SatNOGS Network - Observation 6845790)
This is what my decoder gets from that single observation. @SA2KNG might be able to get a more complete image from more combined observations
Wow. Great photo! Thank you!
this is from db, but most of it is from my stations obs afaict, so not much different from what derek was able to pull out.
I wasn’t able to demod anything from the other obs.
Transmission 09/12/2022 10:13:00
This is my result using Windows command line and the tool “process_frames.py” tool by SA2KNG
I have not found the way to use any other tool succesfully.
Source file created with UZ7HO HS_Soundmodem
Any idea why the image is not correct and complete? Is “process_frames.py” the best tool to work with, at the moment?
73s de David EA4SG
The image sent at 2022-12-10 09:47
the other transmissions made at 21:xx isn’t images but something else, seen here
Ok, I collected more obs and processed for data (many stations does not demod this automatically).
This is the final result:
It looks great. You combined data from several observations ?
Using some additional commands in the “process_frames.py” (thanks Daniel SA2KNG for your help) and some manual edition in the achieved image, this is the best I have been able to get from the Geoscan transmited image dated 09/12/2022 10:13:00.
73 de David EA4SG
Hi all:
My decode using your observation 6845790…
100% correct. Good reception there Daniel.
73
David EA4SG
Hehe this looks like Hudson’s Bay!!
At this point the geoscan-tools has the same processing capability as well
conflict of interest
I also get support from Mr. Derek with his decoding tool but at the moment, running some issues and I have not been succesfull ussing it. Here I use Windows OS to run decoding and processing software. 73 EA4SG
Are more Geoscan image transmissions scheduled for the coming days Sirs?
New image transmissions scheduled:
12.12 10:30
13.12 08:34
13.12 10:04
13.12 11:34
