'GDK_IS_MONITOR (monitor)'
I am seeing multiple instances of the following message in the Gpredict terminal window. I am running a newly installed Ubuntu 22.04 LTS and Gpredict installed from the Ubuntu Software app.
(gpredict:5692): Gdk-CRITICAL **: 11:22:46.987: gdk_monitor_get_workarea: assertion ‘GDK_IS_MONITOR (monitor)’ failed
Does anyone know what this could be? I have done various searches but have not discovered anything pertinent.
Thanks in advance for any help.
Red - KC4LE
Did you solve this problem?
I encountered the same now.
Haven’t looked too cafully at my logs… Does this crash or cause anything bad ?
Is it related to multiple monitors, or when shutting the monitor down ?
Here’s the two places I see that calls that function:
