I’m working on putting together a bill of materials to purchase equipment to use a Yaesu G5500 as a rotator for a station. I have a couple questions, and I’d appreciate any help with them.
1 - Which of the 8 pins on the SatNOGS Arduino Shield output go to the corresponding pins on the DIN port on the Yaesu rotator controller?
2 - How does the Arduino mega connect to the Raspberry Pi running SatNOGS client so that the client can command the rotator using hamlib?
Shield Pin Function G-5500 Pin Function
1 H <——> 6 Provides 2 to 4.5 VDC corresponding to 0 to 450 °
2 R <—-> 2 Connect to Pin 8 to rotate right (clockwise)
3 U <—-> 3 Connect to Pin 8 to rotate up
4 L <—-> 4 Connect to Pin 8 to rotate left (counterclockwise)
5 D <—-> 5 Connect to Pin 8 to rotate down
6 V <—-> 1 Provides 2 to 4.5 VDC corresponding to 0 to 180 °
7 Net-(JP1-Pad7)
8 GND <—-> 8 Common ground
Thank you! When you say USB, does that mean the miniUSB port on the Arduino Mega goes a USB port on the Pi? If so, I assume the Arduino is powered over the DC power supply - is this correct?
You can use Arduino Uno (slightly cheaper) - connector "USB type B" and simply connect to a R-Pi connector "USB type A" with a USB cable USB 2.0 Cable Type A/B. In this case Arduino is powered over USB, but you can also use DC power supply.
