FT-991 not connecting to Hamlib
Having real problems connecting my FT-991 using Hamlib
I have managed to get an IC-7100 connected ok.
The idea is to use the FT-991 TX and IC-7100 RX, I am assuming I can configure both radios in Gperedict .
I configured the FT-991 rigctld command :- -m 1035 -r COM5 -t 4532 -s 38400 -x 1 vvv
When executed I get a blank cmd window.
My IC-7100 command is :- -m 3070 -r COM4 -t 4532 -s 19200 -x 1 -vvv
When executed I get Opened rig model 3070, ‘IC-7100’
I am assuming the Model number is correct 1035. Tried to list the model numbers in rigctrl.exe but cant find the correct command to list them.
Yes this is the first time I have played with Ham Lib and Gpredict. Not having any luck.
Hope someone can point me in the right direction.
Thanks in advance
Ian G4GIR
Please copy your exact command lines! Use MD code fences in your reply.
Probably it is a simple error, not shown yet.
Best 73,
Patrick
