I’m new to this group and to GPredict though I tried it years ago with an old PC running Ubuntu. Never did get it to work right. Can someone point me in the right direction in terms of FT847 rig control and Yaesu G5400B rotor via GPredict.
Welcome to the community, I am not an expert with this setup on Windows but one thing I do know, you need hamlib to integrate GPredict with your radio and Rotor.
Hamlib will act as the software that does the conversion from software to physical connected devices.
I am looking for the same information! The instructions everywhere are for Linux Terminal commands - not Windows 10. If you find the answer please let me know! 73s
Setting up gpredict for use with a Yaesu FT-847 radio.
progs installed:
hamlib-w64-3.3
gpredict 2.2.1 windows version
settings:
FT-847: Menu 37 “CAT RATE” set to 57600
gpredict:
(add your radio to gpredict interface)
=> Edit → Preferences → Interfaces → Add New
Host: 127.0.0.1
Port: 4532
Rig Type: Duplex
PTT status: PTT
VFO Up: SUB
VFO Down: MAIN
LO Down: 0
LO Up: 0
Signalling: AOS LOS
(select your radio in radiocontrol)
=>small arrow down (right side) → radiocontrol)
Settings pane:
Device: YAESUFT-847
Device: None
Cycle: 2500 ( be aware to keep this value at least 2500, lower results in a communication trouble with your ft-847)
Now to make everthing easy i made a batch file to startup.
(my batch file) @echo off
cls
REM start rigctld met instellingen voor ft-847 en gpredict
start C:\hamlib-w64-3.3\bin/rigctld -m 101 -r com3 -t 4532 -T 127.0.0.1
=> where C:\hamlib-w64-3.3\bin/ is the directory hamlib (rigctld) is installed
=> where -m 101 stands for yeasu ft-847
=> where -r com3 is the usb port your cat cable is connected
=> where -t is the portnr for communication
=> where -T is your local host ip adress
timeout /t 5
=> wait 5 sec then start gpredict
REM start gpredict
start /wait G:\gpredict\gpredict-win32-2.2.1\gpredict.exe
=> where G:\gpredict\gpredict-win32-2.2.1\ is the directory gpredict is installed
timeout /t 5
Taskkill /im rigctld.exe
=> when you exit gpredict, rigctrl will terminated after 5 sec.
Now select a sat and track it, don’t forget to engage your radio for automated frequency tracking
This works very well for me, i hope it will do the job for you to.
