An update to Raspberry Pi OS Bullseye
One of the things which we spend a lot of time thinking about here at Raspberry Pi is security. Cyber-attacks and hacking are, sadly, constantly on the increase, and Raspberry Pi computers are as much a target as any other, just because there are so many of them out there nowadays!
Over the years, we have gradually ramped up the security of Raspberry Pi OS; not in response to particular threats, but more as a general precaution. There is always a balance to be struck, however, as security improvements usually carry a cost in terms of usability, and we have tried to keep the system as convenient to use as possible, while having an acceptable level of security.
Up until now, all installs of Raspberry Pi OS have had a default user called “pi”. This isn’t that much of a weakness – just knowing a valid user name doesn’t really help much if someone wants to hack into your system; they would also need to know your password, and you’d need to have enabled some form of remote access in the first place. But nonetheless, it could potentially make a brute-force attack slightly easier, and in response to this, some countries are now introducing legislation to forbid any Internet-connected device from having default login credentials.
So with this latest release, the default “pi” user is being removed, and instead you will create a user the first time you boot a newly-flashed Raspberry Pi OS image. This is in line with the way most operating systems work nowadays, and, while it may cause a few issues where software (and documentation) assumes the existence of the “pi” user, it feels like a sensible change to make at this point.
The new wizard
The Raspberry Pi setup wizard should be a familiar sight by now. It was introduced several years ago, and runs on the first boot, configuring international settings, connecting to wireless LAN and installing any software updates; it also prompts you to change the default password. But the wizard has always been optional – if you pressed “Cancel” on the first page, it just went away and you weren’t forced to use it.
From now on, working through the wizard is no longer optional, as this is how a user account is created; until you create a user account, you cannot log in to the desktop. So instead of running as an application in the desktop itself as before, the wizard now runs in a dedicated environment at first boot.
(https://www.raspberrypi.com/news/raspberry-pi-bullseye-update-april-2022/)
