If you are using a LNA, then your receiver gain is set way too high, which will exacerbate the intermod issue.
A ‘nominal’ starting point for a system with a LNA out front is ~30db of gain, but it depends on your situation. The ‘Setting the gain’ guide can help find a suitable optimal gain value: Omnidirectional Station How To - SatNOGS Wiki
