I justr downloaded the latest firmware version from the github.
During compiling it produces the following error:
Arduino: 1.8.2 (Windows 10), Board:“Arduino/Genuino Uno”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Harry\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Harry\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Harry\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10802 -build-path C:\Users\Harry\AppData\Local\Temp\arduino_build_769337 -warnings=none -build-cache C:\Users\Harry\AppData\Local\Temp\arduino_cache_166450 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose S:\satnogs-rotator-firmware\stepper_motor_controller\stepper_motor_controller.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Harry\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Harry\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Harry\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10802 -build-path C:\Users\Harry\AppData\Local\Temp\arduino_build_769337 -warnings=none -build-cache C:\Users\Harry\AppData\Local\Temp\arduino_cache_166450 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose S:\satnogs-rotator-firmware\stepper_motor_controller\stepper_motor_controller.ino
Using board ‘uno’ from platform in folder: C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20
Using core ‘arduino’ from platform in folder: C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20
Detecting libraries used…
“C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino” “-IC:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\standard” “C:\Users\Harry\AppData\Local\Temp\arduino_build_769337\sketch\stepper_motor_controller.ino.cpp” -o “nul”
“C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino” “-IC:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\standard” “-IC:\Users\Harry\Documents\Arduino\libraries\AccelStepper-1.57.1\src” “C:\Users\Harry\AppData\Local\Temp\arduino_build_769337\sketch\stepper_motor_controller.ino.cpp” -o “nul”
“C:\Users\Harry\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino” “-IC:\Users\Harry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\standard” “-IC:\Users\Harry\Documents\Arduino\libraries\AccelStepper-1.57.1\src” “C:\Users\Harry\AppData\Local\Temp\arduino_build_769337\sketch\stepper_motor_controller.ino.cpp” -o “C:\Users\Harry\AppData\Local\Temp\arduino_build_769337\preproc\ctags_target_for_gcc_minus_e.cpp”
S:\satnogs-rotator-firmware\stepper_motor_controller\stepper_motor_controller.ino:2:18: fatal error: Wire.h: No such file or directory
#include <Wire.h>
compilation terminated.
Bibliotheek AccelStepper-1.57.1 op versie 1.57.1 in map: C:\Users\Harry\Documents\Arduino\libraries\AccelStepper-1.57.1 wordt gebruikt
exit status 1
Fout bij het compileren van board Arduino/Genuino Uno
AsI am not a programmer any suggestions what is wrong??
