Scheduling for first 24h is done. We have ~140 observations for each satellite scheduled.
To station owners have in mind not scheduling too far in the future as these preliminary TLE sets may change a lot.
Payloads deployed according to firefly, waiting for reception from Network:
https://twitter.com/Firefly_Space/status/1576128427144654848
From the first orbit data we have from firefly it looks that the preliminary TLE are quite good so we will keep them for now.
QUBIK-3 and QUBIK-4 are alive!!!
By the way alive QUBIKs means also that the open source deployer PICOBUS by LSF performed well!
Updated TLE sets but we are going to generate in the next minutes even better ones:
SERENITY
1 99332U 22274.35416667 .00000000 00000-0 50000-4 0 03
2 99332 136.9700 127.9769 0041780 141.1890 322.0512 16.06727959 06
FOSSASAT-1B
1 99333U 22274.35416667 .00000000 00000-0 50000-4 0 04
2 99333 136.9700 127.9769 0041780 141.1890 322.0512 16.06727959 07
GENESIS-G
1 99334U 22274.35416667 .00000000 00000-0 50000-4 0 05
2 99334 136.9700 127.9769 0041780 141.1890 322.0512 16.06727959 08
GENESIS-J
1 99335U 22274.35416667 .00000000 00000-0 50000-4 0 06
2 99335 136.9700 127.9769 0041780 141.1890 322.0512 16.06727959 09
QUBIK-4
1 99336U 22274.35416667 .00000000 00000-0 50000-4 0 07
2 99336 136.9700 127.9769 0041780 141.1890 322.0512 16.06727959 00
QUBIK-3
1 99337U 22274.35416667 .00000000 00000-0 50000-4 0 08
2 99337 136.9700 127.9769 0041780 141.1890 322.0512 16.06727959 01
Is this valid data in this observation? SatNOGS Network - Observation 6553795
Is there a dashboard?
Yes, real data!
Dashboards: Qubiks-3 & -4
More accurate TLE set, still not perfect but better than the previous ones:
SERENITY
1 99332U 22274.35416668 .00000000 00000-0 50000-4 0 04
2 99332 136.9700 127.9769 0041780 141.1890 324.0701 16.06727959 08
FOSSASAT-1B
1 99333U 22274.35416668 .00000000 00000-0 50000-4 0 05
2 99333 136.9700 127.9769 0041780 141.1890 324.0701 16.06727959 09
GENESIS-G
1 99334U 22274.35416668 .00000000 00000-0 50000-4 0 06
2 99334 136.9700 127.9769 0041780 141.1890 324.0701 16.06727959 00
GENESIS-J
1 99335U 22274.35416668 .00000000 00000-0 50000-4 0 07
2 99335 136.9700 127.9769 0041780 141.1890 324.0701 16.06727959 01
QUBIK-4
1 99336U 22274.35416668 .00000000 00000-0 50000-4 0 08
2 99336 136.9700 127.9769 0041780 141.1890 324.0701 16.06727959 02
QUBIK-3
1 99337U 22274.35416668 .00000000 00000-0 50000-4 0 09
2 99337 136.9700 127.9769 0041780 141.1890 324.0701 16.06727959 03
I’ve removed my scheduled observations for the next 24h as the TLE have significantly changed and scheduled for the next 12h with the new TLE.
To station owners… if you have scheduled observations for satellites of this launch check them to see if the plot is still relevant and re-schedule (remove and schedule again) if the pass is too off.
A new TLE set in “TO BE ASSIGNED” status is published by space-track.org.
We are going to follow this object for the satellites for now until we have any additional information:
0 TBA - TO BE ASSIGNED
1 53955U 22122 22274.52776567 .00001176 -37213-5 00000+0 0 9994
2 53955 136.8927 129.7142 0045292 164.1049 228.1015 16.09142950 37
Scheduling for the next 24h is done.
Has anything been heard from the satellites (that we have freqs for) OTHER THAN the QUBIK pair?
I’ve been watching online but have only seen confirmed reports from those two.
Unfortunately nothing heard from the rest of the satellites. Also from the latest observations the TLE are too off… we are going to generate new tomorrow. But probably it will need to generate TLE sets pretty often as they are getting old easily.
Not getting any decode with any of my normal 9k6 tools using the I/Q from EU1SAT from the QUBIK sats:
https://twitter.com/EU1SAT/status/1576380682674110464
… should these be standard FM-demod 9600 GMSK or something else?
Those packets are CCSDS Space Packets with FEC, GFSK or BPSK with residual carrier. You can use the GNURadio Flowgraphs provided in the QUBIK gitlab repo, located in the test/ folder.
Edit: link to the comms software repo test/flowgraphs · master · librespacefoundation / Qubik / COMMS Software · GitLab
New TLE sets from space-track.org, 5 in total while we have at least 7 satellites + the rocket, so we expect more to come:
1 53955U 22122A 22275.28938525 .00001183 -37430-5 00000+0 0 9991
2 53955 136.8955 134.5921 0045440 166.1350 326.7842 16.11220721 151
1 53956U 22122B 22275.16731825 .00001203 -38065-5 00000+0 0 9991
2 53956 136.9184 133.8153 0046318 173.5383 337.2326 16.13938292 121
1 53957U 22122C 22275.28966922 .00001182 -37376-5 00000+0 0 9993
2 53957 136.8837 134.5605 0038285 165.5279 331.9204 16.13448532 146
1 53958U 22122D 22275.22146662 .00001184 -37439-5 00000+0 0 9991
2 53958 136.8804 134.1280 0049880 159.1045 307.0699 16.14125816 82
1 53959U 22122E 22275.28949060 .00001173 -37091-5 00000+0 0 9993
2 53959 136.8855 134.5963 0035833 173.0535 318.5557 16.10151830 95
From these QUBIK 3 and 4 fit better 53958, with 53956 be also close but probably describes the other LANE of PICOBUS which hosted GENESIS G and J and FOSSASAT-1B.
So, for now I’ve changed in DB and Network the TLE we follow as described bellow:
QUBIK 3, 4 → OBJECT D 53958
GENESIS G, J and FOSSASAT-1B → OBJECT B 53956 (guess)
SERENITY → OBJECT C 53957 (guess)
To station owners, TLE sets have been changed a lot again, if you have scheduled on your station these satellites, please re-check and re-schedule if necessary.
PS I’m going to re-schedule in the next couple of minutes the observations I’ve scheduled yesterday.
Re-scheduling for the next 24h is done. Some info about it:
For passes over 30 degrees we have ~25 observations for each satellite
For passes from 10 to 30 degrees we have ~50 observations for each satellite
FOSSASat-1B Heard a couple times over TinyGS and shows good SNR, however indeed satnogs has not picked up the Morse beacon. tinygs-webapp
New TLE set generated by SatNOGS Team(@cgbsat) for QUBIK 3 and 4:
QUBIK 3
1 99337U 22275.22146663 .00000000 00000-0 00000-0 0 02
2 99337 136.8804 134.1280 0049880 159.1045 308.6323 16.14125816 06
QUBIK 4
1 99336U 22275.22146663 .00000000 00000-0 00000-0 0 01
2 99336 136.8804 134.1280 0049880 159.1045 308.6323 16.14125816 05
