I’m sure others here are involved in the other sats, but I’m most familiar with Serenity, which will have a transmitter at 437.1 MHz 4k8 FM with AX25. I believe it will beacon for the first 72 hours, then after that will send status packets when it receives command packets from any ham on the same frequency. There’s some details here: Serenity | Teachers In Space, Inc.
So it is probably time to get these sats into the database to be ready for launch!
The GENESIS-L and GENESIS-N satellites, designed and built by AMSAT-EA in collaboration with students from the European University and ICAI, will be launched, in a first attempt, on September 2, once the American company Firefly has carried out the static test of the Alpha launcher, this being the last step before its launch. The vehicle is ready for takeoff on its platform from Vanderberg Air Force Base in California and carries, for this inaugural flight, many other satellites from various organizations and universities.
The GENESIS are digital repeating satellites of ASK and CW and also carry Applied Ion Systems’ AIS-gPPT3-1C experimental ion thrusters.
The working frequencies of the satellites are as follows:
GENESIS-N
145.888 MHz uplink, Modes: CW and ASK 50 bps
436.888 MHz downlink CW ASK 50 bps, am3sat callsign
The description of the telemetry and the mode of operation of its repeaters can be found in the following links:
Link to telemetry transmissions description (in English)
Alan,
For pumping data into the DB I think we are ready! For a dashboard there’s the satnogs-decoder missing. I’ll see if I can find time to build one, but time is something I’m lacking the most
In our documentation you can also find ways to receive and transmit to the QUBIK twins. Give it a try, and help us monitor and communicate with our open source radio amateur experiments.
SatNOGS will of course be ready to receive QUBIKs (DB, Network and Dashboards) by the time of the launch as with most missions nowadays that publish their information.
We will be publishing a more specific call to action for radio amateurs around the world soon.
It is also worth mentioning that the Pocketqubes in this mission are integrated and will be deployed from PICOBUS , our very own LSF built open source Pocketqube deployer!
WU2M0 audio level = 130 [NONE] ||||
Audio input level is too high. Reduce so most stations are around 50.
[0.1] WU2M0>WU2M0:H1 BA97 BB95 S6.12 LT+40.1573 LN-76.2106 DT 00:41:23 2020/11/24<0x0a>
