are you running your station on raspberry ? try check and connect your raspberry to monitor, and check whats is going on.
or if you have another micro sd card, you can try install and setup fresh raspberry os. just to make sure there is no problem with your hardware.
i leave here link to alternate tutorial for new satnogs setup
