Hi everybody!
After a couple of week testing an HackRFone I decided to revert to my old setup with an RTL V3 dongle.
Changed parameters to fulfill RTLSDR dongle, I’m experiencing an issue: observation starts but nothing in /tmp/.satnogs/data, so failed observation.
Before this last test session all went fine and smooth…
With journalctl -f -u satnogs-client.service
this is the output:
-- Logs begin at Fri 2021-10-01 19:27:44 UTC. --
Oct 01 19:33:32 raspberrypi satnogs-client[351]: requests.exceptions.ConnectionError: HTTPSConnectionPool(host='network.satnogs.org', port=443): Max retries exceeded with url: /api/jobs/?ground_station=311&lat=45.726034&lon=12.262917&alt=10 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb2284530>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Oct 01 19:33:32 raspberrypi satnogs-client[351]: apscheduler.executors.default - ERROR - Job "get_jobs (trigger: interval[0:01:00], next run at: 2021-10-01 19:34:31 UTC)" raised an exception
Oct 01 19:33:32 raspberrypi satnogs-client[351]: Traceback (most recent call last):
Oct 01 19:33:32 raspberrypi satnogs-client[351]: File "/var/lib/satnogs/lib/python3.7/site-packages/apscheduler/executors/base.py", line 125, in run_job
Oct 01 19:33:32 raspberrypi satnogs-client[351]: retval = job.func(*job.args, **job.kwargs)
Oct 01 19:33:32 raspberrypi satnogs-client[351]: File "/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py", line 177, in get_jobs
Oct 01 19:33:32 raspberrypi satnogs-client[351]: response.raise_for_status()
Oct 01 19:33:32 raspberrypi satnogs-client[351]: UnboundLocalError: local variable 'response' referenced before assignment
Oct 01 19:39:03 raspberrypi satnogs-client[351]: apscheduler.executors.default - WARNING - Run time of job "get_jobs (trigger: interval[0:01:00], next run at: 2021-10-01 19:34:31 UTC)" was missed by 0:00:32.156298
Oct 01 19:39:03 raspberrypi satnogs-client[351]: apscheduler.executors.default - WARNING - Run time of job "post_data (trigger: interval[0:03:00], next run at: 2021-10-01 19:36:32 UTC)" was missed by 0:02:31.723619
This is my satnogs-setup report:
"versions": {
"satnogs-client": "1.6",
"satnogs-client-ansible": "202109022142",
"gr-satnogs": "2.3.1.1-1",
"gr-soapy": "2.1.3.1-1",
"gnuradio": "3.8.2.0-14satnogs2",
"satnogs-config": "0.12"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"date": "2021-10-01T18:52:43.767495+00:00",
"distribution": {
"DESCRIPTION": "Raspbian GNU/Linux 10 (buster)",
"RELEASE": "10",
"CODENAME": "buster",
"ID": "Raspbian"
"pending-updates": false,
"platform": {
"system": "Linux",
"node": "raspberrypi",
"release": "5.10.63-v7l+",
"version": "#1457 SMP Tue Sep 28 11:26:14 BST 2021",
"machine": "armv7l",
"processor": ""
"memory": {
"total": 1963110400,
"available": 1747955712,
"percent": 11.0,
"used": 121561088,
"free": 1504497664,
"active": 98172928,
"inactive": 296607744,
"buffers": 49049600,
"cached": 288002048,
"shared": 9191424,
"slab": 34406400
"disk": {
"total": 62526631936,
"used": 4706385920,
"free": 55256903680,
"percent": 7.8
"configuration": {
"enable_iq_dump": true,
"iq_dump_filename": "/tmp/.satnogs/iq.raw",
"satnogs_antenna": "RX",
"satnogs_post_observation_script": "/home/pi/tests/postob.sh {{ID}} {{FREQ}}",
"satnogs_pre_observation_script": "/home/pi/tests/preob.sh -f {{FREQ}}",
"satnogs_rf_gain": "29",
"satnogs_rx_samp_rate": "1024000",
"satnogs_station_elev": "10",
"satnogs_station_id": "311",
"satnogs_station_lat": "45.726034",
"satnogs_station_lon": "12.262917",
"satnogs_waterfall_max_value": "-61",
"satnogs_waterfall_min_value": "-67"
Any hints???
Tnx de Victor, I3VFJ
p.s.: with rtl_sdr -f 144.8M -g 48 -s 250000 -n 1000000 iq.dat
I get a good iq.dat, so I do not think to an USB issue; moreover tests with spyserver + remote SDR# are fine…
