Experimental support for truncating priority passes around existing observations in satnogs-auto-scheduler
Hello everyone,
I have been experimenting with an extension to satnogs-auto-scheduler that allows priority passes to be truncated around already scheduled observations, instead of dropping the entire pass when only part of it overlaps an existing observation.
The implementation is now available in my GitLab fork:
Repository:
Branch:
feature/truncate-overlaps
The branch currently contains the following commits:
00fb13c Add optional truncated overlap scheduling
6dff8b5 Apply truncation only during priority scheduling
6a48e35 Isolate truncated scheduling to priority transmitters
0157aa3 Fix overlap checks after truncated scheduling
This is currently an experimental implementation, not an upstream SatNOGS feature.
I have been running it continuously on my SatNOGS stations 4394 and 4434, 5049 for several weeks, and so far it appears to be working reliably.
The published branch also passes the GitLab CI lint, test, and build jobs.
Motivation
I use a priority list for satellites that I particularly want to receive.
However, if a priority pass partially overlaps an observation that has already been scheduled on the station, the normal scheduling behavior may result in the whole candidate pass being discarded, even when a useful portion of the pass is still available.
For example:
Existing observation
Priority pass
Normal behavior:
   [ dropped completely ]
With truncation:
Another possible case is:
Priority pass
Remaining windows
The purpose of this modification is therefore to preserve usable portions of explicitly prioritized passes whenever possible.
Implementation approach
satnogs-predict already provides several overlap-handling modes, including:
OverlapHandling.DROPOverlapHandling.TRUNCATEOverlapHandling.FULL
so much of the underlying functionality was already available.
I added an optional argument to satnogs-auto-scheduler:
--truncate-overlaps
An important design decision was not to apply TRUNCATE to every candidate pass.
Instead, I use two candidate pools:
Normal candidate pool
    -> OverlapHandling.DROP
Explicit priority-transmitter pool
    -> OverlapHandling.TRUNCATE
This is intentional.
If all passes are predicted using TRUNCATE, the candidate set available to the normal scheduler can change significantly. That can alter normal auto-scheduler behavior even for transmitters that are not explicitly included in the priority file.
Therefore, when --truncate-overlaps is enabled:
  1. All transmitters are predicted using the original DROP behavior.
  2. Transmitters explicitly listed in the priority file are additionally predicted using TRUNCATE.
  3. Priority scheduling uses the truncated priority-pass pool.
  4. Normal gap filling continues to use the original DROP candidate pool.
Conceptually:
drop_passes = find_passes(    ...,    overlap_handling=OverlapHandling.DROP,)truncated_priority_passes = find_passes(    ...,    overlap_handling=OverlapHandling.TRUNCATE,)
The second prediction is performed only for transmitters explicitly listed in the priority file.
For truncated scheduling, the planning configuration is approximately:
PlanningConfig(    overlap_handling=OverlapHandling.TRUNCATE,    split_long_windows=False,    overlap_padding=Duration.from_seconds(wait_time_seconds),)
Normal candidates continue to be handled by the existing ordered_scheduler().
An overlap-check issue found during testing
During the initial implementation, I found an issue in my overlap check.
The first version effectively checked the candidate together with the entire collection of occupied ranges. As a result, a candidate could be rejected because two unrelated occupied ranges overlapped each other, even when the candidate itself did not overlap them.
I changed the check so that the candidate is compared individually against each occupied range:
def _overlaps_existing(predicted_pass, occupied_ranges, wait_time_seconds):    candidate_range = _predicted_pass_to_time_range(predicted_pass)    for occupied_range in occupied_ranges:        ordered_ranges = sorted(            [occupied_range, candidate_range],            key=lambda time_range: time_range.start,        )        if has_range_list_overlap(            ordered_ranges,            padding=Duration.from_seconds(wait_time_seconds),        ):            return True    return False
After this change, unrelated overlaps between existing observations no longer caused valid new candidates to be rejected.
A small positive WAIT value seems important
During actual scheduling, I also encountered cases where two observations whose boundaries exactly touched were rejected by SatNOGS Network as overlapping.
For example:
Observation A:
16:50:00 - 16:57:09
Observation B:
16:57:09 - 17:05:00
Using:
-w 1
or, in my local wrapper configuration:
WAIT=1
gives a one-second separation:
Observation A:
16:50:00 - 16:57:08
Observation B:
16:57:09 - 17:05:00
and this has worked reliably in my testing.
The same value is also used as overlap_padding during truncated planning.
For this reason, I recommend using a small positive WAIT value when experimenting with this implementation.
Example output
The scheduler now produces messages such as:
Truncated priority pass NORAD 68795:
2026-09-22 17:31:52.135628+00:00
2026-09-22 17:39:34.857957+00:00
In actual operation, I have observed multiple priority passes being truncated and successfully fitted between already scheduled observations during the same scheduler run.
Current usage
In my local wrapper, I enable this behavior using:
TRUNCATE_OVERLAPS=1
WAIT=1
which is translated to:
--truncate-overlaps
-w 1
Transmitters that are not explicitly listed in the priority file continue to use the original DROP behavior.
Testing and caveats
A few notes:
  • This is currently experimental and is not an upstream SatNOGS feature.
  • I recommend testing with dry-run mode first.
  • Only explicitly configured priority transmitters are truncated.
  • Normal candidates intentionally retain the original DROP behavior.
  • A small positive observation spacing such as WAIT=1 appears useful because exact boundary equality may still be rejected by SatNOGS Network.
  • I have operated this implementation continuously for several weeks on stations 4394 and 4434, 5049 without seeing problems related to the truncation feature.
  • The published branch passes the GitLab CI lint, test, and build jobs.
  • The branch is currently based on an earlier upstream master revision. I intend to rebase it onto the latest upstream version before considering an upstream merge request.
During testing I also encountered some separate edge cases in satnogs-predict involving non-finite propagated coordinates from problematic orbital data. I am treating those separately, since they are not caused by this truncation implementation.
Acknowledgements
This implementation was developed with assistance from ChatGPT, which I used as a coding and debugging assistant while investigating the scheduler behavior, reviewing implementation approaches, and troubleshooting several edge cases.
The implementation decisions, testing, and operation on my SatNOGS stations were carried out and verified by me.
I would be very interested in feedback on this approach, especially:
  • whether keeping the normal DROP candidate pool separate from the truncated priority pool makes sense;
  • whether the overlap handling could be simplified;
  • and whether something similar could be useful as an optional upstream feature.
73,
Kazuki NISHIOKA, JF6FYI
Cool Idea and thank you for spending your time on this. I will have a look.
Thank you also for being frank on the ChatBot usage. I might be mistaken here, but it get the impression, that this forum post was written with Chatty too. I have mixed feelings about this. I’d definitely prefer to interact with you as a person, instead trough a ChatGPT-Generated text.
If you wrote that post yourself, nevermind.
Dear @mhuebner ,
Thank you for your reply and for pointing this out.
You are correct. I did use ChatGPT to help write and structure the post. As a non-native English speaker, I was worried that a long explanation of a complicated technical topic would become difficult to read, so I used it as a writing aid.
I also used ChatGPT as a technical assistant during the implementation and debugging. However, I reviewed and applied the changes myself and tested them on my stations.
I understand that you would prefer to interact with me directly. I will keep that in mind and try to use my own wording more in future posts.
Thank you again for the feedback.
73,
First of all, I think NISHIOKA-san’s feature proposal for truncating priority passes is a fantastic and very practical approach for SatNOGS operators!
As a fellow Japanese developer, I’d like to share a quick perspective on the AI usage topic.
For many of us who are non-native English speakers, AI tools like ChatGPT or Gemini are not used to “lazily generate posts,” but rather as essential accessibility tools to bridge the language gap and share technical ideas accurately.
To be fully transparent, this comment itself was translated with the help of Gemini!
Out of genuine curiosity, does this text still feel unnatural or give you that “AI-generated” vibe? I’d love to hear your honest impression as a native speaker!
Feedback from native speakers like you is super valuable—not only for us to learn, but also to feed back into AI tools so they can learn to write more natural, human-like English!
cool. this script push your station rank :smiley: awesome
Hello @bali ,
Thank you very much for your reply!
If it’s not too much trouble, I would appreciate any comments or feedback you might have regarding the scheduler’s usability or the code implementation.
74
can you update , because it 4 commits behind the main
Hi @bali,
Thank you very much for offering your assistance.
I have rebased my feature branch onto the latest upstream master.
I would appreciate it if you could take a look.
I have also tested the updated branch with a dry run on Station 5049 (uhf-2).
For your reference, I am also attaching the wrapper script and configuration file from my local environment.
satnogs-auto-scheduler_ Local Configuration Sample File.zip (3.0 KB)
73,
i test it, and overall all work. i also try truncate-overlaps. i notice this good for normal / long obs.
i also test -w 1 , as you say, its good to fix the overlap error.
Hi bali,
Thank you very much for trying out truncate-overlaps so quickly!
Thank you very much for your kind comments.
for other people that want try, can run with this command :
pip install --no-cache-dir --upgrade "git+https://gitlab.com/nishikazu0417/satnogs-auto-scheduler.git@feature/truncate-overlaps"
