Hello friends.
My ground station (#255) es running now.
I can read an error on log:
satnogsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
rotctld is disabled on setup.
How can i solve it?
Thank’s a lot.
Nov 21 17:28:58 raspi satnogs-client[17913]: 2018-11-21 17:28:58,126 - satnogsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
Nov 21 17:28:58 raspi satnogs-client[17913]: Exception in thread Thread-1488:
Nov 21 17:28:58 raspi satnogs-client[17913]: Traceback (most recent call last):
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
Nov 21 17:28:58 raspi satnogs-client[17913]: self.run()
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/usr/lib/python2.7/threading.py”, line 754, in run
Nov 21 17:28:58 raspi satnogs-client[17913]: self.__target(*self.__args, **self.__kwargs)
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 142, in _status_interface
Nov 21 17:28:58 raspi satnogs-client[17913]: sock.bind()
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/commsocket.py”, line 104, in bind
Nov 21 17:28:58 raspi satnogs-client[17913]: self.s.bind((self._TCP_IP, self._TCP_PORT))
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/usr/lib/python2.7/socket.py”, line 228, in meth
Nov 21 17:28:58 raspi satnogs-client[17913]: return getattr(self._sock,name)(*args)
Nov 21 17:28:58 raspi satnogs-client[17913]: error: [Errno 98] Address already in use
Nov 21 17:28:58 raspi satnogs-client[17913]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
Nov 21 17:28:58 raspi satnogs-client[17913]: 2018-11-21 17:28:58,179 - satnogsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
Nov 21 17:28:58 raspi satnogs-client[17913]: Exception in thread Thread-1487:
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 134, in _communicate_tracking_info
Nov 21 17:28:58 raspi satnogs-client[17913]: self.send_to_socket(p, sock)
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 180, in send_to_socket
Nov 21 17:28:58 raspi satnogs-client[17913]: position = sock.send(“p\n”).split(’\n’)
Nov 21 17:28:58 raspi satnogs-client[17913]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/commsocket.py”, line 76, in send
Nov 21 17:28:58 raspi satnogs-client[17913]: self.s.send(message)
Nov 21 17:28:58 raspi satnogs-client[17913]: error: [Errno 32] Broken pipe
Nov 21 17:28:59 raspi satnogs-client[17913]: [WARNING] /tmp/dpkg/gr-satnogs/lib/cw_to_symbol_impl.cc:106: Dot symbol samples: 654
Nov 21 17:28:59 raspi satnogs-client[17913]: [WARNING] /tmp/dpkg/gr-satnogs/lib/cw_to_symbol_impl.cc:107: Window size: 109
Thanks for reporting this. For no-rotator setup you can ignore this error until it is fixed.
There is an issue for tracking its fix in gitlab.
