Hello,
I just installed the client on a brand-new PI-4 and I always get the same error.
Here the complete log of one observation:
Mar 01 19:13:51 on4vki satnogs-client[1511]: rot_init called
Mar 01 19:13:51 on4vki satnogs-client[1511]: dummy: _init called
Mar 01 19:13:51 on4vki satnogs-client[1511]: rot_register (1)
Mar 01 19:13:51 on4vki satnogs-client[1511]: rot_register (2)
Mar 01 19:13:51 on4vki satnogs-client[1511]: dummy_rot_init called
Mar 01 19:13:51 on4vki satnogs-client[1511]: rot_open called
Mar 01 19:13:51 on4vki satnogs-client[1511]: dummy_rot_open called
Mar 01 19:13:51 on4vki satnogs-client[1511]: rot_get_position called
Mar 01 19:13:51 on4vki satnogs-client[1511]: dummy_rot_get_position called
Mar 01 19:13:51 on4vki satnogs-client[1511]: rot_set_position called
Mar 01 19:13:53 on4vki satnogs-client[1511]: [ERROR] SoapySSDPEndpoint::sendTo(udp://[ff02::c]:1900) = -1
Mar 01 19:13:53 on4vki satnogs-client[1511]: sendto(udp://[ff02::c]:1900) [99: Cannot assign requested address]
Mar 01 19:13:53 on4vki satnogs-client[1511]: Found Rafael Micro R820T tuner
Mar 01 19:13:53 on4vki satnogs-client[1511]: [INFO] [UHD] linux; GNU C++ version 8.2.0; Boost_106700; UHD_3.13.1.0-3
Mar 01 19:13:55 on4vki satnogs-client[1511]: [INFO] Using format CF32.
Mar 01 19:13:55 on4vki satnogs-client[1511]: thread[thread-per-block[1]: <block soapy::source(1)>]: RtAudio init error 'RtApiPulse::probeDeviceOpen: error connecting input to PulseAudio server.
The image installed is “2019-09-11-Raspbian-SatNOGS-lite.img” with all latest updates (29/02/2020).
Can anybody help me. Thanks!
