I just setup my station for satnogs, i am facing this error and have double checked the key and URL and find it to be correct. Pls help to resolve the error in subject line.
(ERROR - 401 Client Error: Unauthorized for url: SatNOGS Network API>)
First I have removed your private API Token as you have shared it in the screenshot above. This means that you will need to renew it (just go a grab it again, this will regenerate it) and change it the sudo satnogs-setup (don’t forget to hit the apply button after the change).
If you need again to share your configuration in the future please copy paste the output of the support report generated by the menu item Advanced -> Support from sudo satnogs-setup.
Thank you , i have regenerated the API and updated it . Used “Apply” too in the basic setup. But my station is shown “OFFLINE” in network.satnogs page.
Also is there a way to access local page from RPI using http://:port# ? what is the default port number used ? sorry for late response as i was away from home and reconnected back recently.
Cheers
Divakar
