auk
1
Hello,
The CSUM is doing a RadiHam challenge on their 1U CubeSat ENSO.
The first hint is in the beacon right now
To cite them (from X @CSUM_F4KJX):
Starting soon, the beacon will transmit 4 GPS coordinates — can you find the hidden point based on these coordinates ?
Cheers!
bali
4
manual decode using linux:
- download the .ogg file from your observation result
- convert into wav
sox input.ogg output.wav
- decode using gr_satellites,
gr_satellites 58470 --wavfile output.wav
example result:
→ Packet from 9k6 FSK downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u'F4KJX' (total 5)
ssid = Container:
ch = True
ssid = 0
extension = False
Container:
callsign = u'FX6FRC' (total 6)
ssid = Container: ch = True ssid = 0
extension = True
control = 0x03
pid = 0xF0
info = b'\x8c\x10\xa8]\xcch\xa5]\xcch\xfb\x1f\x04U\xe8\xa3\x00\x00/\x01]\xc6U\xca\xf9\xc3\xca\xca>b\xec\x0e\x0e9\x00\x83(?\x03\xec\xf1\xef\xf7\xcad\xc9{\xdc\x9bT\t\x00\x00\xc8\x11\x92\x0
3w\x0f\x00\xcd\n\x9b\xbd\x99F\x01}\x11\x1e\x02\x00l\x00m\xbf\x003\x00\x1d\x01\x0c\x005\x001\x00\x00\x00\x02\x02\x01\x07\x00|\xfe\xc8\xfe\xb4\xeb\xa8\x00\x11\x00\x10\x00\x0c\x00\x00\x00\x00\x
00\x00\x00\x00\x00\x00\x00H1:53.338/-6.259
dl7ndr
5
Live decoded the same beacon at 20:57:28 UTC with gr_satellites.
dl7ndr
6
Today on the pass beginning at 10:57 UTC I’ve decoded 9 times the same coordinates (H1).
bali
9
-> Packet from 9k6 FSK downlink
Container:
header = Container:
Container:
ssid = Container:
ch = True
ssid = 0
extension = False
Container:
ssid = Container:
ch = True
ssid = 0
extension = True
control = 0x03
pid = 0xF0
info = b'\x8c\x10Pb\xd1hKb\xd1h\xe2\x00\x04U\xc0\xe0\x00\x000\x01\xd7\xc6U\xc3\x06\xbf\xc3\xc3\x00b\xf8\x0e\r:\x00}(\x00\xf8\xfb\xf8\xf9\xf7\xcad\xc9Z\xb7wV\t\t\n\xc9\x11\x97\x03w\x06\x00z\x07\x9c\xbe\x99F\x0e\x7f\xfe\x1e\x02\x01\x05\x01\x06\xc3\x007\x00(\x01\r\x00:\x00:\x00\x00\x00\x02\x02\x01\x07\x00\x8c\xfe\xe8\xff`\xf7\x8c\xff\xf1\x00\x0f\xff\xf8\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00H2:41.67.12.452
H1:53.338/-6.259
H2:41.67.12.452
Latitude: 41.6700° N
Longitude: 12.4520° E
