Hi just need a bit of advice sent this comand to arduino +cnc shield but motor dose not move.
is this the correct responce
many thanks
Peter(G4GRK)rotctl, Hamlib 3.2
Report bugs to hamlib-developer@lists.sourceforge.net
rot_init called
initrots3_easycomm called
rot_register (201)
rot_register (202)
rot_register (204)
rot_open called
serial_open called
serial_setup called
Opened rot model 202, ‘EasycommII’
rig_strstatus called
Backend version: 0.4, Status: Beta
Rotator command: P145
Azimuth: Elevation: 34
rot_set_position called
easycomm_rot_set_position called: 145.000000 34.000000
easycomm_transaction called: AZ145.0 EL34.0 UP000 XXX DN000 XXX
serial_flush called
write_block called
write_block(): TX 35 bytes
0000 41 5a 31 34 35 2e 30 20 45 4c 33 34 2e 30 20 55 AZ145.0 EL34.0 U
0010 50 30 30 30 20 58 58 58 20 44 4e 30 30 30 20 58 P000 XXX DN000 X
0020 58 58 0a XX.
Rotator command:
