Different gain settings used in NOAA script?
Looks Like default settings rather than user configurable gain settings used in satnogs_noaa_apt_decoder.py
self.osmosdr_source_0.set_gain(satnogs.hw_rx_settings[rx_sdr_device]['rf_gain'], 0)
self.osmosdr_source_0.set_if_gain(satnogs.hw_rx_settings[rx_sdr_device]['if_gain'], 0)
self.osmosdr_source_0.set_bb_gain(satnogs.hw_rx_settings[rx_sdr_device]['bb_gain'], 0)
self.osmosdr_source_0.set_antenna(satnogs.hw_rx_settings[rx_sdr_device]['antenna'], 0)
EDIT:
self.osmosdr_source_0.set_gain(satnogs.handle_rx_rf_gain(rx_sdr_device, rf_gain), 0)
self.osmosdr_source_0.set_if_gain(satnogs.handle_rx_if_gain(rx_sdr_device, if_gain), 0)
self.osmosdr_source_0.set_bb_gain(satnogs.handle_rx_bb_gain(rx_sdr_device, bb_gain), 0)
self.osmosdr_source_0.set_antenna(satnogs.handle_rx_antenna(rx_sdr_device, antenna), 0)
Maybe I do not understand this code so well.
It could explain why I see different backgrounds in waterfalls between NOAA passes and Meteor at similar frequencies.
NOAA 18
Meteor pass was next
Notice the difference in background noise.
@surligas any comments?
Sorry for being late,
which version of gr-satnogs do you use? v1.1.0 does not use only the hard-coded values. Custom gains etc can be passed through the available command line options.
satnogs_noaa_apt_decoder.py --help will give you the available parameters.
Difference in noise and signal levels can also be caused by different bandwidth used by two different receivers. As far as I know the FFT size is the same for each receiver, so if the bandwidth increases, so will the power level in each FFT bin.
I have been using the v1.1.0 version of gr-satnogs. Different bandwidth could explain the difference. This had been bugging me for a while.
Thanks.
