Determining satellite main control GS and the quality of each SATNOGS GS
There must be some way by determining the amount of packets decoded where a satellite main GS is located? Else the amount of packets decoded is determined by the packet rate of the specific satellite beacon and the elevation of the pass?
So if many packets are decoded then it means that the observation GS must be in close proximity of that satellites main control GS?
Would be interesting to determine this for some satellites
Also some way of determining which SATNOGS GS is better than other. Some way of determining which is best?
Of course ones with tracking big antennas is the best, unless there LNA makes the station worse
omni, non-tracking antennas with LNA comes after
