Decoding packets from TIANWANG 1C ( 40926) modulation and decoding
Regarding Observation 1798894
The modulation used by TIANWANG 1C is wide GFSK at 19200 baud, but decoded as AX100 at 4800 baud (succesfully decoded ).
Thanks for the info, I’ve added transmitters for GMSK9k6 on all TIANWANG satellites. There should be available for scheduling.
@uy0ll feel free if you spot any other missing or wrong info to add a suggestion for change/addition directly in DB, you just need to go to the satellite page and hit either “Add new transmitter” button or the “Edit” button on an existing one.
