Debian Bookworm and higher are moving away from pulseaudio and it is replaced by pipewire.
For those that where using audio routing with pulseaudio here is the pipewire replacement.
Place the following config in $HOME/.config/pipewire/pipewire.conf.d
custom.conf
context.modules = [
{ name = libpipewire-module-loopback
args = {
node.description = "My Loopback"
audio.position = [ FL FR ]
capture.props = {
media.class = Audio/Sink
node.name = my_virtual_sink
node.description = "My Virtual Sink"
playback.props = {
node.name = "my_virtual_sink.output"
node.passive = true
target.object = "my-default-sink"
Restart pipewire systemctl --user restart pipewire and when starting pavucontrol you will see the new sink and loopback.
