Just upgraded my station to Debian 12 and the SatNOGS client fails to start - giving the following info’:
satnogs-client.service - SatNOGS client
Loaded: loaded (/etc/systemd/system/satnogs-client.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Tue 2023-06-13 10:53:47 BST; 1min 43s ago
Duration: 57ms
Process: 708 ExecStart=/var/lib/satnogs/bin/satnogs-client (code=exited, status=1/FAILURE)
Main PID: 708 (code=exited, status=1/FAILURE)
CPU: 53ms
Warning: some journal files were not opened due to insufficient permissions.
Can someone please advise how to fix it?
Currently the SatNOGS client will not run on Debian 12 (Bookworm) stay on Bullseye.
One of the challenges is the new GNURadio version.
Currently SatNOGS is using version 3.8 and Debian 12 comes with 3.10 and in that version some functions have changed.
Thanks again PE0SAT. Understandable.
73 Roger M0ROJ
