Good morning,
I have a station with Toshiba Satellite L300 / Debian 11 Bullseye. The station (3600) was working fine with SDR RTL V2. I try to upgrade to SDR RTL V4.
I followed the steps from https://www.rtl-sdr.com/rtl-sdr-quick-start-guide/ ( Getting Started on Linux).
For the Soapy driver with V4 support I cloned from GitHub - pothosware/SoapyRTLSDR: SoapySDR RTL-SDR Support Module
After that, I installed libsoapysdr-dev from Debian – Package Download Selection – libsoapysdr-dev_0.7.2-2_amd64.deb.
Now, the station 3600 is receiving, but I can not modify any settings in satnogs-setup.
There are some information about setup.
$ rtl_test
Found 1 device(s):
0: RTLSDRBlog, Blog V4, SN: 00000001
Found Rafael Micro R828D tuner
RTL-SDR Blog V4 Detected
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
^CSignal caught, exiting!
User cancel, exiting…
Samples per million lost (minimum): 0
ristian@yo4dft:~$ SoapySDRUtil --probe="driver=rtlsdr"
## Soapy SDR -- the SDR abstraction library ##
Probe device driver=rtlsdr
[INFO] Opening Generic RTL2832U OEM :: 00000001...
-- Device identification
driver=RTLSDR
hardware=R828D
index=0
origin=https://github.com/pothosware/SoapyRTLSDR
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: YES
Time sources: sw_ticks
Other Settings:
* Bias Tee - RTL-SDR Blog V.3 Bias-Tee Mode
[key=biastee, default=false, type=bool]
-- RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Full gain range: [0, 49.6] dB
RF freq range: [24, 1764] MHz
Filter bandwidths: [0, 8] MHz
“versions”: {
“satnogs-client”: “1.8.1”,
“satnogs-flowgraphs”: “1.5-1”,
“gr-satnogs”: “2.3.5.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: false,
“pending-tags”: null
“system”: {
“date”: “2024-06-12T07:46:35.391671+00:00”,
“distribution”: {
“DESCRIPTION”: “Debian GNU/Linux 11 (bullseye)”,
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Debian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “yo4dft”,
“release”: “5.10.0-29-amd64”,
“version”: “#1 SMP Debian 5.10.216-1 (2024-05-03)”,
“machine”: “x86_64”
“memory”: {
“total”: 2984091648,
“available”: 1038753792,
“percent”: 65.2,
“used”: 1664995328,
“free”: 187863040,
“active”: 510722048,
“inactive”: 1986539520,
“buffers”: 59990016,
“cached”: 1071243264,
“shared”: 100016128,
“slab”: 146710528
“disk”: {
“total”: 238530957312,
“used”: 14027231232,
“free”: 212312416256,
“percent”: 6.2
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_ppm_error”: “0”,
“satnogs_rf_gain”: “36.4”,
“satnogs_station_elev”: “50”,
“satnogs_station_id”: “3600”,
“satnogs_station_lat”: “44.141”,
“satnogs_station_lon”: “28.617”
Press Enter to continue…
When I try to update configuration tool,
tarting Ansible Pull at 2024-06-12 10:49:41
/usr/bin/ansible-pull -d /root/.satnogs/ansible -U https://gitlab.com/librespacefoundation/satnogs/satnogs-client-ansible.git -o -t satnogs-setup local.yml -C stable
/usr/lib/python3/dist-packages/paramiko/transport.py:219: CryptographyDeprecationWarning: Blowfish has been deprecated and will be removed in a future release
"class": algorithms.Blowfish,
[WARNING]: Could not match supplied host pattern, ignoring: yo4dft
localhost | SUCCESS => {
"after": "e6b68d6755a085f79c6c4697d75b055d3699b36a",
"before": "e6b68d6755a085f79c6c4697d75b055d3699b36a",
"changed": false,
"remote_url_changed": false
Repository has not changed, quitting.
When I try to APPLY the settings modifications
/usr/lib/python3/dist-packages/paramiko/transport.py:219: CryptographyDeprecationWarning: Blowfish has been deprecated and will be removed in a future release "class": algorithms.Blowfish, Executing playbook local.yml - localhost on hosts: localhost - Gathering Facts... Check Ansible version... Check distribution... Remove APT configuration disabling recommends... Update APT cache... Install required package for APT... Install repository keys... Remove old repository... Install repository... Install packages... Gather package facts... Disable swap file... Add ZRAM init script... Create needrestart directory for Raspbian... Configure needrestart for Raspbian... Remove deprecated satnogs-setup system dependencies... Install satnogs-setup system dependencies... Retrying... (1 of 4) Retrying... (2 of 4) Retrying... (3 of 4) localhost failed | msg: No package matching 'needrestart' is available - Play recap - localhost : ok=10 changed=0 unreachable=0 failed=1 rescued=0 ignored=0
Any idea or help is welcome,
Cristian - YO4DFT
