DC offset correction
Am I right that you remove DC offset using the following algorithm:
  • set up center frequency a bit left or right
  • filter DC using low pass filter
  • shift result back
Why don’t you remove DC using the same algorithm used in sdr# or gqrx? Here is an example: https://github.com/ghostop14/gr-correctiq
