I’ve built a dashboard which gives an overview about who used how often, when first and last the digipeaters of the following satellites.
- IRIS-C
- GRBBeta
- BDSat-2
- Veronika
- SONATE-2
- ISS
- EOS-7
- NO-44
Very nice activity. Would it be possible to separate the digipeats V/V and U/U via BDSAT-2 or GRBBeta, or at least indicate the band per packet? It can be usefull.
Thank you. Tomas OK2PNQ
Hi Tomas,
This is an interesting point!
Unfortunately, there is no way to distinguish between a digipeated frame received on VHF or UHF.
Both satellites use their only callsign (without any SSID) on both bands.
If we could ask the users to for example use mycall-2 for VHF and mycall-7 for UHF, we could distinguish it!
Or to use for example VHF and UHF as destination callsign.
Daniel
Hi Daniel and all:
Which one of those 9K6 U/U digipeaters is easiest to use and has more traffic over EU?
Are you going to add GRBAlpha?
73 de David EA4SG
Hi David,
Compared to Veronika, GRBBeta and BDSat-2 hear the best and they are both very low on traffic as you can see on the dashboard.
I first wanted to add GRBAlpha as well, but had to painfully realize that its decoder is buggy. GRBAlpha would repeat a packet via OM9GRB-7. But once the decoder reads a via callsign, it discards the packet.
73
Daniel
I’ve added LASARsat and CroCube to the Digipeater Dashboard.
Both satellites provide a 9k6 digipeater on UHF.
Added YOMOGI to Digipeater Dashboard.
