CZ-6C Launches: JAMX01 + BY70-4:2026-08-25 03:30UTC
Yesterday, some Chinese media outlets reported that the JAMX01 satellite will be launched on August 25 via the Long March 6C (CZ-6C) rocket into a 500 km Sun-Synchronous Orbit (SSO).
The launch site is the Taiyuan Satellite Launch Center. Below is the frequency coordination for JAMX01:
IARU Sat Coordinator
Launch time looks is 03:30UTC 11:30BJT
SatNOGS DB entry
Thank him @BG7ZDQ for providing the relevant information.
This mission currently has two CubeSats (JAMX01/BAYI04) confirmed and awaiting launch, with identical launch times.
As for the orbital elements, we may need to use relevant tools to generate them.
JAMX01 AND BAYI04s SatNOGS DB entry all successful
The BAYI04 satellite inherits the frequency coordination from BAYI03; therefore, its downlink is at 437.443 MHz, BPSK 9k6.
Thanks BG2GFC for this information. On question : by inherits the frequency coordination from BAYI03 what do you mean ?
73
As the name suggests, “inherited frequency coordination” means inheriting frequency coordination from the previous satellite.
The BAYI03 satellite has already re-entered the atmosphere, while BAYI04 was developed as its replacement.
Therefore, BAYI04 can reuse BAYI03’s frequency coordination, which is also in compliance with IARU (International Amateur Radio Union) rules.
Guess you mean BY70-3.
Please show us exactly the rule you are speaking of.
https://community.libre.space/t/new-satellite-harbin-microsat/15189/4
Like this
That still doesn’t answer the question on if the IARU coordinated BY70-4 at all. As BY70-4 is not mentioned at all on the IARU website. (Meaning there was no attempt to coordinate it.) This just shows that BG2BHC told AMSAT the same thing your telling us now basically.
Thanks for the information.
Is it possible to share preliminary TLE and IQ recordings so we can prepare and make these deployments a success ?
Thank you for your support.
The number of payloads for this launch remains uncertain; currently, only these two are known to us.
The initial orbital elements could be calculated, but I don’t know how.
For BY70-4, simply use the corresponding ASRTU decoder.
JAMX01 is still unknown for now.
Hi Jan,
Thanks! Due to policy considerations, unfortunately it would not be appropriate for us to release the preliminary TLE directly before deployment.
But I can share some low-precision information that should be enough to build a rough orbit for preparation:
Orbit: approximately 530 × 545 km
Inclination: approximately 97.5°
Separation is expected at around 11:35 local time (UTC+8).
At the time of separation, the spacecraft should be roughly*near the southernmost part of Vietnam.
Passes predicted from this information may be off by several minutes, but hopefully it is enough to build an approximate orbit for initial preparation.
You can use the ASRTU-1 decoder for Harbin MicroSat as well.
Thanks for the information, will the Launch Site 9A at the Taiyuan Satellite Launch Center in northern China be used ?
Yes.
From Taiyuan.
Taiyuan Satellite Launch Center only LC-9A can launch CZ-6C rocket
You are right​:+1:
Harbin MicroSat (8104、BY-04、BY70-4、八一04星、8104 Harbin MicroSat、哈尔滨号) is a science education microsatellite developed by the LilacSat Team at Harbin Institute of Technology (HIT).
Drawing on its experience in the development of science education satellites and payloads, including the ASRTU Micro-Satellite, the LilacSat Team designed Harbin MicroSat as a next-generation platform for science education and student participation in space missions.
The satellite has a mass of approximately 18.7 kg and is designed to operate in a 500 ± 25 km Sun-synchronous orbit (SSO), with a planned on-orbit lifetime of one year. It is equipped with deorbit and autonomous collision-avoidance capabilities. Its attitude determination accuracy is ≤0.1° (3σ), pointing accuracy is ≤0.3° (3σ), and attitude stability is ≤0.05°/s (3σ).
The payloads include a high-definition camera, a science education display, a miniature camera, a polarization camera, and a short-message transponder. The high-definition camera provides at least 8 MP resolution and supports 4K video at 30 fps, while the 720p display can be remotely controlled from the ground to display educational content for space imaging activities.
The miniature camera has a 2592 × 1944 pixel sensor with a 90° field of view and supports 1920 × 1080 JPEG and SSDV imagery. SSDV images can be transmitted during ground-station passes with support for packet-loss retransmission.
The polarization camera has a resolution of 4112 × 3008 pixels, four polarization channels, and a spectral range of 400–760 nm. It is intended for polarization remote-sensing observations of the atmosphere and Earth’s surface.
The spacecraft uses X-band and UHF/VHF communications. Its amateur-radio frequency coordination is inherited from the 8103 satellite. The UHF telemetry downlink operates on 437.443 MHz using 9600 bps BPSK and is compatible with the ASRTU telemetry format. The X-band communication system supports data rates of at least 1 Mbps.
Harbin MicroSat is scheduled for launch aboard a CZ-6C launch vehicle on August 25, 2026, at approximately 03:30 UTC (11:30 Beijing Time).
SatNOGS DB - Suggestion for Satellite None - Harbin MicroSat
I am confused, is this sat actually IARU coordinated or are yous just reusing an old coordination freq meaning this sat was not coordinated?
There is actually a precedent for this.
Ref:AMSAT ANS-187 (2020)
BY70-2 reused/shared BY70-1’s IARU coordination after BY70-1 reentered. AMSAT explicitly said:
“As a replacement, the satellite is sharing BY70-1’s IARU coordination and ITU API notification.”
BY70-3/8103 also has an IARU coordination for 437.443 MHz:(IARU BY70-3 record
The same applies to BY70-3/8103 and BY70-4/8104: BY70-4 is sharing BY70-3’s previous coordination.
Was this reuse coordinared with IARU? Would be nice if they published records about reuse that the allowed. Since as of right now there is no document from IARU saying this sat was coordinated.
