I have a Raspberry PI 4, site #2682 that works when i schedule through the dashboard. However I want to used a client such as CubicSDR to run the SDR that way on occasion. I can’t connect to the SoapyServer – bind, here is some diagnostics. What am i doing wrong?
pi@raspberrypi:/tmp $ SoapySDRUtil --find
## Soapy SDR – the SDR abstraction library ##
[INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-4satnogs1
RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (default), No such file or directory.
No devices found!
pi@raspberrypi:/tmp $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:/tmp $ ps -ef | grep sat
satnogs 383 1 0 00:21 ? 00:01:36 /var/lib/satnogs/bin/python3 /var/lib/satnogs/bin/satnogs-client
pi 3390 1994 0 18:46 pts/0 00:00:00 grep --color=auto sat
pi@raspberrypi:/tmp $ ps -ef | grep Soap
pi 3392 1994 0 18:46 pts/0 00:00:00 grep --color=auto Soap
-----------here is the output when I put in the address and port----------------------
SoapyServerListener::accept([::ffff:192.168.1.109]:48854)
SoapyServerListener::close()
thank you.
Barry, K0BVT
