Cooperation with IoT Satelites
Is there’s an IoT Satellite using LoRa Transceiver currently up an running, that I could incorporate with to test my LoRa-Based ground sensor terminal?
Hi @saber and welcome in the community!
You can find info for transmissions in SatNOGS DB. Check the transmitters page and filter with “LoRa” at the top right filter field.
Do note that LoRa is not supported by -client and -flowgraphs due to the proprietary modulation, it is possible to see in the waterfall but not demodulate.
Projects such as TinyGS does it with a hardware solution, and therefore has much more focus on this specific modulation.
