And is not difficult to built one by yourself but maybe you need a good
substrate: FR4 has too much loss for this purpose, every tenth of dB of loss
became a tenth of dB increase of NF
Does it depend on the internal build of the antenna or would that be possible for all 2x2 MIMO antennas ?
I suppose the antenna has two orthogonal dipole or similar so each got a
polarization and can be combined with 90deg phasing to obtain rhcp or lhcp
If possible would it bring some benefits ?
If sat is not stabilized signal will not change with attitude using cp
Or just better build a helix ?
I’ve no experience with the antenna you mention but for what it cost it could
be a good attempt; I’ve no experience with S-band sats, too…
Never designed an RF board yet so this could be an interesting projects. but doing it right will take some time and a bunch of prototypes. So maybe i can find an existing hybrid quadrature coupler to start with.
At least i’ll start experimenting with kicad’s rftool suite. Yes, a good substrate will be required.
The internal looks like two ‘leaf’ shaped orthogonal dipoles on a PCB with 2 discs in front that look like directors. Will investigate some more the internals. I guess the ‘leaf shaped’ dipoles are about to provide the wide bandwidth.
Thanks for your valuable input, will definitively try to find more about it and do some tests.
