Hello
My ground station is # 810, I am currently working with an omnidirectional antenna and I am working on the installation of the satnogs rotator.
I already built the Satnogs rotator, but I had problems connecting it with shield-Arduino nano - Raspberry pi-3
I am doing the installation of satnogs-rotator-firmware and I stopped in step (.Build the code) I don’t know how to do that “make” and the following connection steps.
Can someone help me to continue the installation?
I appreciate your collaboration!!!
g7kse
November 1, 2019, 12:27pm
2
I’m not sure exactly where you are stuck. Have you followed the CNC shield route? wiki link
I am really installing librespacefoundation / SatNOGS / satnogs-rotator-firmware · GitLab because I want to install the driver on Raspberry pi3.
I go in step * Build the code
I’m still missing steps and performing a test I get the following error
Thanks!!
My device arduino is connect in Bus 001 Device 007: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
DL4PD
November 1, 2019, 4:45pm
6
Ok, please do paste the output of
$ ls -al /dev/ttyUSB*
My Raspberry has had an unexpected shutdown, it doesn’t work, I think I’ll install the last image again
Hello again friend!
I had problems with my Raspberry and I had to change it, I continued with the installation of the rotator Satnogs and this was the result of his suggestion
DL4PD
November 10, 2019, 8:02am
9
Be sure your user pi is member of the group dialout.
Hello Patrick
I am performing the rotor connection tests using https://gitlab.com/librespacefoundation/satnogs/satnogs-rotator-firmware#testing-with-hamlib-rotctl-or-with-serial-monitor
The step motors are energized but do not move. Just feel a pulse in them, as if they were trying to move but they don’t, this when using P 10 10 like test
Thanks!!!
DL4PD
November 19, 2019, 6:09am
12
Unfortunately I do not have any experience with the controller hardware yet, so all my hints will be guesses. Maybe @azisi could chime in here…
azisi
November 22, 2019, 9:46am
13
