Since I have a VHF antenna at my station, I’d like to add it to the network as well. However, it is rotated by the same rotator, and it is attached to a second (remote) RTL-SDR. What is the proper way to set up the stations for dual-band reception, with one of them having priority over the other? Maybe same client, but uses different SDR for each band? I don’t know if it’s supported.
The simplest solution is to combine the antennas with a diplexer. Next option is to use a switching relay between the two.
Having two clients with two sdr’s on a single rotator will probably be a poor compromise.
I was thinking: can I switch the SDR with a pre-observation script? If I can, then my problem is solved. One station is scheduled for VHF/UHF reception and based on the frequency, I can select the proper SDR.
@SA2KNG: is rtl_tcp supported in the 1.9.2+sa2kng version?
I don’t know of such a switching routine. when using several on one host, they are usually separated by serial or similar. the flowgraph then always selects that serial.
