I’ve built a decoder and dashboard for CO-65 (CUTE-1.7+APD II) to show the telemetry of CW beacons.
Please upload data to populate the dashboard.
Hi.
Can you explain the easiest way to upload data?
73 de David EA4SG
Hi David,
You have to upload manually as described on this dashboard’s panel.
Feel free to contact me in case of problems.
Using IN80cp as your locator, only change the bold marked values (date and time in UTC and the telemetry usually starting by ‘87’).
It’s a one liner at the command prompt.
curl --data ‘noradID=32785&source=EA4SG×tamp=2024-07-27T14:05:00Z&frame=4355544587CC9F993C292672565B17&locator=longLat&longitude=3.792W&latitude=40.646N’ https://db.satnogs.org/api/telemetry/
73
Daniel
Hi David,
I’ve built an online form for uploading beacons to be shown on CO-65’s dashboard.
It’s similar to the one for AISat.
This should be the easiest way to upload data.
73
Daniel
