I dont know if I am missing something or am not understanding the instruction but I cant seem to get the arduino firmware setup for the life of me. I have tried both the instruction on the satnogs website and the Quartapound firmware and am struggling to understand what is going wrong with my setup.
Unfortunately Quarterpound was a little short of comments so I had to put them in myself to understand the firmware behavior. Here is a cut down version showing my comments and modification for different Az/El gear ratios.
@filefile stepper_motor_controller_rotor22.ino
2023 December. Az/El Rotor built from a Pan/Tilt pedestal.
Augmented changes by Robert Denize to handle Az and El gear ratios not being the same.
This is the documentation for satnogs rotator controller firmware
for stepper motors configuration. The board (PCB) is placed in
satnogs-rotator-controller and is for releases:v2.0, v2.1, v2.2
@section
@section dependencies Dependencies
This firmware depends on <a href="http://www.airspayce.com/mikem/arduino/AccelStepper/index.
htmlhttp://www.airspayce.com/mikem/arduino/AccelStepper/index.html">
AccelStepper library being present on your system. Please make sure you
have installed the latest version before using this firmwa@sectione.
@section license License: Licensed under the GPLv3.
#define SAMPLE_TIME 0.1 ///< Control loop in s
#define RATIO_AZ 9 ///< Gear ratio of rotator gear box, Az.
#define RATIO_EL 7 ///< Gear ratio of rotator gear box, El.
#define MICROSTEP 4 ///< Set Microstep
#define MIN_PULSE_WIDTH 20 ///< In microsecond for AccelStepper
#define MAX_SPEED 800 ///< In steps/s, consider the microstep
#define MAX_ACCELERATION 800 ///< In steps/s^2, consider the microstep
#define SPR 1600L ///< StepsPerRevolution of stepping motors. eg 360/1.88= 1600.
#define MIN_M1_ANGLE 0 ///< Minimum angle of azimuth
#define MAX_M1_ANGLE 360 ///< Maximum angle of azimuth
#define MIN_M2_ANGLE 0 ///< Minimum angle of elevation
#define MAX_M2_ANGLE 180 ///< Maximum angle of elevation
#define DEFAULT_HOME_STATE LOW ///< Change to LOW according to Home sensor. See endstop.h where a flag is set
///‘true’ when endstop switch goes “on”. Care must be taken to isolate electrical crosstalk noise reaching the
///communication cable from the stepper motor driving cables. It should be separated and shielded.
///There is some advantage to make the endstop switch “off” (HIGH) at endstop rather than “on” (LOW).
#define HOME_DELAY 12000 ///< Time for homing Deceleration in millisecond
I see you said 2.0-2.2, I guess I should have mentioned I am building v3.1
ok, I cannot find where you are getting v3.1 from, I certainly cannot find this firmware version. I do suspect there may be confusion with the CNC shield being identified as v3.
Ok, I was just reffering to the rotator version. Not the software. I am following now
What are the different versions, I’ve only ever seen 2 of them that being the standard satnogs firmware and the qourtapound software
