Firstly, my apologies if this is covered elsewhere and I missed it. Here is a 3-axis CNC GRBL controller board for $10 US:
Has anyone attempted to run the satnogs-controller-firmware on one of these boards? Obviously the 3rd axis is not needed, that should free up some I/O ports for other uses. Maby it’s easily hackable to support DC motors too. Mainly curious because this could help bring the cost of a rotator down significantly if it’s usable. Thanks!
I’m going to hijack my own thread to note cheaper alternatives to parts for the reference platform. This is in no way a knock against the V3 reference platform, it was a necessary step up from the V2 design to support higher duty cycles. However I feel the cost of the ground station can still be brought further down without sacrificing too much quality. Otherwise it seems that a complete ground station is in the same cost ballpark as a Yaesu G-5500.
The reference controller, excluding the enclosure and cable glans I expect to round out at around $100. That’s a rough guesstimate, and I would be happy to be corrected if someone has built one.
So I went ahead and ordered the parts I referenced earlier for testing. I’m comfortable enough with the Arduino platform that I’m hopeful I can make the SatNOGS firmware run on this board, assuming the cpu has enough memory. Fingers crossed.
