Hello all,
This morning I clone the repo “satnogs-auto-scheduler” in order to schedule new observations.
I followed the instructions in README.md file and i was able to test it.
As you can see the following log.
(env) seb@Leonardo [~/Documents/codings/SATNOGS/satnogs-auto-scheduler] (master)$ ./schedule_single_station.py -n -s 793 -P /tmp/cache/priorities_793.txt -f -z
2020-03-15 17:29:08,834 - root - INFO - Requesting information for ground station 793
2020-03-15 17:29:09,195 - root - INFO - Ground station information retrieved!
2020-03-15 17:29:09,201 - root - INFO - Finding all passes for 143 satellites:
100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 143/143 [00:00<00:00, 236.76it/s]
2020-03-15 17:29:09,814 - root - INFO - Requesting scheduled passes for ground station 793
2020-03-15 17:29:10,011 - root - INFO - Scheduled passes for ground station 793 retrieved!
2020-03-15 17:29:10,013 - root - INFO - Found 2 scheduled passes between 2020-03-15 17:39:08 and 2020-03-15 18:39:08 on ground station 793
2020-03-15 17:29:10,013 - root - INFO - 2 passes selected out of 41, 1458 s out of 3470 s at 42.017% efficiency
2020-03-15 17:29:10,013 - root - INFO - GS | Sch | NORAD | Start time | End time | El | Priority | Transmitter UUID | Mode | Satellite name
2020-03-15 17:29:10,014 - root - INFO - 793 | Y | 33591 | 2020-03-15T17:36:45 | 2020-03-15T17:48:41 | 35 | 1.000000 | kE4VaYKpnFmzEquEjKKi8D | |
2020-03-15 17:29:10,014 - root - INFO - 793 | Y | 25338 | 2020-03-15T18:22:13 | 2020-03-15T18:34:35 | 80 | 1.000000 | mjsHcYajEgbiS9cbKfecGo | |
2020-03-15 17:29:10,014 - root - INFO - Done.
However I am not able to schedule futures observations via crontab. Here is error log
Traceback (most recent call last): File "./schedule_single_station.py", line 9, in <module> import settings File "/home/seb/Documents/codings/SATNOGS/satnogs-auto-scheduler/settings.py", line 4, in <module> from decouple import config ModuleNotFoundError: No module named 'decouple'
How can I fix this issue ?
Thanks in advance
