File “/var/lib/satnogs/bin/satnogs-client”, line 6, in
from satnogsclient import main
File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/init.py”, line 13, in
from satnogsclient.locator import locator
File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/locator/locator.py”, line 5, in
import gps
ImportError: No module named gps
the automatic upgrade was not simple… I had to sudo apt-get install needrestart, to clear up the upgrade/ no start issue.
is it solved now?
If not please post the results of “Advanced > Support” from satnogs-setup.
Cheers!
Yes It all cleared up after sudo apt-get install needrestart, then I when back and did an update and apply in the old satnogs setup. That did upgrade the system.
