Hello! I have just updated my station 858 to client v1.3.2 and for observations with mode FSK 9600 I get ‘variable_ax100_mode5_decoder_0’ is not defined. All other modes I using seems to work fine.
Any ideas?
Log:
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: rot_init called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: dummy: _init called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: rot_register (1)
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: rot_register (2)
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: dummy_rot_init called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: rot_open called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: dummy_rot_open called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: rot_get_position called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: dummy_rot_get_position called
jun 06 08:43:35 SM0TGUSATNOGS satnogs-client[387]: rot_set_position called
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: Traceback (most recent call last):
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: File “/usr/bin/satnogs_fsk.py”, line 499, in
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: main()
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: File “/usr/bin/satnogs_fsk.py”, line 484, in main
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, framing=options.framing, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: File “/usr/bin/satnogs_fsk.py”, line 72, in init
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: self.available_framings = available_framings = {‘ax25’:variable_ax25_decoder_0, ‘ax100_mode5’:variable_ax100_mode5_decoder_0, ‘ax100_mode6’:variable_ax100_mode6_decoder_0}
jun 06 08:43:40 SM0TGUSATNOGS satnogs-client[387]: NameError: name ‘variable_ax100_mode5_decoder_0’ is not defined
jun 06 08:43:44 SM0TGUSATNOGS satnogs-client[387]: satnogsclient.observer.observer - ERROR - Failed to rename encoded file
jun 06 08:43:44 SM0TGUSATNOGS satnogs-client[387]: satnogsclient.observer.observer - ERROR - Failed to rename data file
jun 06 08:43:44 SM0TGUSATNOGS satnogs-client[387]: satnogsclient.observer.observer - ERROR - No waterfall data file found
