Hi, try to reinstall Client Setup Ansible on Raspberry Pi from the artifacts 2023 11 14 img file. Put back my localhost backup file with my personal data. Appear correct in satnogs-setup…:
Satnogs-client didn’t recognize my configuration…
VE2DSK
The ansible config is separate from the environment file, that is generated when you use “apply”.
Many thanks… When import local host file backup, I have to change almost 1 item on setup tor the process. VE2DSK
